Weight reduction? - Mustang Evolution
Old 09-12-2015, 10:30 PM   #1
alecas447's Avatar
Weight reduction?
I've been going to the strip a lot lately have raced a few modded cars and surprisingly kept up ,
I don't plan on doing any bolt on mods for a few months so I really want to shed some weight any help? Soccelover any ideas? I remember you had a thread on this but I couldn't find it
alecas447 is offline   Reply With Quote
Old 09-13-2015, 12:46 AM   #2
Depends on how extreme you want to get.
For me ive done:
Rear Seat delete
Aluminum driveshaft
Spare Tire & Jack removed
Swapped to Fixed back race seats.
When i did the pan hard bar and torque arm i removed the dogbone on the differential as well as the quad shocks. But of course i still have the added weight of the torque arm, pan hard bar, and subframe connectors.
With all the weight taken off and the other weight added i'm at about 3275lbs with 1/2 tank. I know a few people with 99-04s at 2800ish, but they don't have the added suspension i do and they also don't have the same aluminum intake manifold i have.
Be warned though. The more you take out, the suckier the car will be to drive around if its your daily.
Old 09-13-2015, 12:46 AM   #3
Here is that super long list BTW.
The Ultimate Weight Reduction List - Forums at Modded Mustangs
Old 09-13-2015, 01:06 AM   #4
retiredvet's Avatar
Each 100lbs is roughly a tenth in the quarter. Also factor in 12lbs per gallon of fuel in your tank approx.
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 09-13-2015, 07:08 AM   #5
Gasoline weighs about 6lbs per gallon.
Old 09-13-2015, 07:38 AM   #6
parkerz28's Avatar
Correct ^
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 09-13-2015, 09:03 AM   #7
alecas447's Avatar
It's 8 ib per gallon, yes it's my daily and I've thought about remaoving my spare but it's come in handy before
Old 09-13-2015, 10:44 AM   #8
parkerz28's Avatar
Google it water is around 8 gasoline is six
Old 09-13-2015, 12:46 PM   #9
Diesel weighs about 7.5lbs.
Old 09-13-2015, 12:53 PM   #10
Slater2111's Avatar
I am about to do some lightening up too. I am getting a driveshaft shop aluminum drive shaft, rear seat delete and removing the rear seat belts. I'm replacing the rear lower control arms with maximum Motorsport ones. New all aluminum radiator. I'll probably take out the black boxes behind the rear tires while I'm at it all along with the dogbone. And I'm doing he ultimate weight reduction myself. Loosing weight! I gained a lot after I got out of the Marines due to my back injuries. And eating like I was still in didn't help.
Slater2111 is offline   Reply With Quote
Old 09-13-2015, 01:04 PM   #11
If you want to get serious
MM Tubular K member & A Arms = -65lbs
Swap to Aluminum Block = -80lbs
If you want to go all out race car 2350 is possible. It has been done in a New Edge.
Old 09-13-2015, 01:17 PM   #12
Slater2111's Avatar
I might also swap out my leather power seats for a pair of manual racing seats.
Old 09-13-2015, 01:27 PM   #13
I dropped about 46lbs going from power leather seats to my fixed back race seats. Then another 14lbs when i took out the factory seat belts ( i have 5 point harnesses).
Old 09-13-2015, 01:51 PM   #14
retiredvet's Avatar
Heh you guys and google. Rule of thumb has always been 12 per. Additives, water, crud plus always erring on the conservative side especially when you are trying to dial in your bracket. No reason to give up any amenities on your street car, your gonna pick up a tenth at best and without proper weight transfer you could actually lose on the 60 foot. On a strip/weekend street car you can go all out with fiberglass body panels and all the deleted amenities, just makes no sense on your driver.
Old 09-13-2015, 02:15 PM   #15
Slater2111's Avatar
Every little bit helps. Properly set up is very important too
Old 09-13-2015, 05:35 PM   #16
All depends on the person's tolerances.
My car is my daily and i've taken out the back seats, gutted the trunk. Taken out some of the padding behind the interior panels, done race seats and harnesses, car has a pretty stiff suspension also. At times yeah it does kind of suck. But its not too bad. I got used to it. More worried about how the car handles.
Old 09-14-2015, 03:36 PM   #17
Panther140's Avatar
Gas mileage tho!
If you're worried about weight, you should definitely be worried about wind drag. People underestimate how much power it takes just to push a car through the air at 100 mph.
Panther140 is offline   Reply With Quote
Old 09-14-2015, 04:07 PM   #18
Sounds like you need this
Old 09-14-2015, 06:53 PM   #19
parkerz28's Avatar
Or just buy a Camaro/firebird ... Yep I said it lol
Old 09-14-2015, 08:06 PM   #20
tj@steeda's Avatar
There are several options that we have that will reduce the weight & help at the track:
Here is the lightweight radiator support Steeda 2005-10 Mustang Lightweight Radiator Support - Made in USA 555-5075 | Free Shipping!
This will save you around 10 lbs.
Lower control arms which will help with launch & weight: Steeda 2005-14 Mustang Billet Rear Lower Control Arms - Made in USA 555-4405 | Free Shipping!
They will save several pounds over stock.
Lastly, a nice weight saving upgrade is the driveshaft - Steeda Mustang GT 3.5" Aluminum Driveshaft (05-10) 238-steeda-1766 | Free Shipping!
This will provide a range of benefits:
53% lighter than OEM driveshaft
750 HP Rating
2450 ft.lbs torque rating
Lightweight aluminum one-piece driveshaft
Improved driving performance
Quicker acceleration, lower ET's
Direct bolt-in, easy installation
No increase in NVH
There are others ... but these are some pretty big weight savings with added value.
Let me know if I can help put a package together for you when your ready to take the next step ... you can always reach me at tim@steeda.com.
Best Regards,
TJ[COLOR="Silver"]
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 09-14-2015, 08:36 PM   #21
750 HP Rating
No increase in NVH
Best Regards,
TJ[COLOR="Silver"]
Wrong year. We all have 96-04s
Old 09-15-2015, 04:47 AM   #22
jeno's Avatar
Lol you beat me to it
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 09-15-2015, 07:42 AM   #23
tj@steeda's Avatar
Well then ... having multiple windows open will cause that, lol:
Some of the parts will still apply:
Steeda 1999-04 Mustang Rear Lower Control Arms - Made in USA 555-4421 | Free Shipping!
Ford Racing 1996-04 Mustang Aluminum Driveshaft 161-M-4602-J | Free Shipping!
Also 6 lbs. lighter than stock.
We have several members on the team that frequent the strip ... I would be happy to put you in contact with them!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 09-15-2015, 09:07 AM   #24
Panther140's Avatar
If you're hard core enough to sacrifice amenities for weight reduction, just go all the way.
http://www.vettereport.com/gallery/2...ide-_thumb.jpg
Old 09-15-2015, 10:13 AM   #25
tj@steeda's Avatar
Or ... you could just do that!!
Awesome.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 09-15-2015, 11:59 PM   #26
Most of all you want front end reduction. K member, A Arms, tubular bash bar
That'll cut 70lbs minimum depending on the brands you choose.
Weight reduction ideas poloka 2011-2014 Mustang GT 12 03-23-2014 12:51 PM
Weight reduction Blackedout Pre-2005 V6 Mustang 3 01-29-2012 05:51 PM
Hardcore Weight Reduction Dan Pre-2005 V6 Mustang 8 06-03-2005 08:28 AM
99-04 Weight Reduction! fastmustangs1 The Bar 8 04-23-2005 07:00 AM
weight reduction ? ERICK Pre-2005 V6 Mustang 19 11-11-2003 10:10 AM
04:14 AM
