02 heater tube fitment problem - Mustang Evolution
Old 09-13-2015, 09:11 PM   #1
Blue Angel's Avatar
I got a 02 4.6 motor that i am building from the ground up. Im having a problem with the heater tube truing to fit it to the block. I have a nipple for it but the tube does not fit in it. Is there a piece that i am missing to connect the 2? The outter diameters are the same. Help please. The pixs of what i have and how it is to be used. TIA
Sent from my SM-N910P using Mustang Evolution mobile app
ID:	191113   Click image for larger version
Blue Angel is offline   Reply With Quote
Old 09-13-2015, 09:20 PM   #2
Blue Angel's Avatar
Originally Posted by Blue Angel View Post
I got a 02 4.6 motor that i am building from the ground up. Im having a problem with the heater tube trying to fit it to the block. I have a nipple for it but the tube does not fit in it. Is there a piece that i am missing to connect the 2? The outter diameters are the same. Help please. The pixs of what i have and how it is to be used. TIA
Old 09-14-2015, 05:25 AM   #3
fenixignition's Avatar
IIRC, that fitting on the right is only used on a PI head upgrade on an non pi engine/car.
2002 GT 5sp. 16x,xxx miles
Old 09-14-2015, 05:35 AM   #4
Blue Angel's Avatar
So i dnt even need the nipple then? But if i just use the heater tube it doesnt match up at the end of the block
Old 09-14-2015, 07:54 AM   #5
That part im not sure. I can take a look behind my engine, but the intake manifold and everything is on it. But maybe i can see something and get a picture of it for you if no one else has an answer before then. I just cant remember how it was hooked up in the back of it.
Old 09-14-2015, 08:35 AM   #6
Blue Angel's Avatar
I went to the junkyard and look on a couple of them some of them have the nipple and others don't but the two I got straight from the manufacturer Ford and if I put it in without the nipple the tube is too short and the nipple I got was also from Ford and it is the same diameter as the tube
Long tube or short tube headers for acceleration Mustang47 Pre-2005 V6 Mustang 7 10-31-2013 03:41 PM
Long tube vs short tube 94CobraUSMC 1979-1995 Mustang GT 15 06-24-2013 01:24 PM
a/c heater and radio problem 02StangGT 1996-2004 Mustang GT 4 03-16-2013 05:16 PM
Long tube header vs. short tube USMCSS 1996-2004 Mustang GT 5 12-24-2006 05:06 PM
My heater scuks in fumes when I turn on the heater jaynez31 Pre-2005 V6 Mustang 3 02-08-2006 06:44 PM
08:34 AM
