On3 is here! - Mustang Evolution
Old 09-15-2015, 11:37 AM   #1
bwright1973's Avatar
On3 is here!
Got my kit yesterday! I have my injectors,mass air, bbk upper all I have to decide on is what k-frame to use and coil overs without breaking the bank!! And input would be most appreciated!
bwright1973 is offline   Reply With Quote
Old 09-15-2015, 11:46 AM   #2
The On3 kit is designed around the UPR kit. I know it won't fit with QA1 and a few others. Unsure about the MM kit. If you want to be 100% sure, get the UPR. Its the lightest and one of the cheapest too and the UPR K is USA made believe it or not.
Old 09-15-2015, 12:00 PM   #3
My concern with the upr is its for straight line how will it hold up for a daily driver??
Old 09-15-2015, 12:59 PM   #4
For a DD, totally fine. The only time you might find it wanting is if you are doing extreme corner carving but just going around corners fast in a DD, all good.
Old 09-15-2015, 01:15 PM   #5
For someone who don't know you sure know a lot!! Lol upr it is! How bad do coil overs ride
Old 09-15-2015, 01:19 PM   #6
Depends on spring rates and struts. I'd honestly get the MM coilover kit and MM CC plates. The UPR ones are not as well made.
Old 09-15-2015, 01:39 PM   #7
What's a good spring rate for a stock car?? 200lbs???
Old 09-15-2015, 11:57 PM   #8
Just go MM everything.
K member and coilovers. K member is super strong, and the coilovers are good quality. Also they give you a whole bunch of different hyper coil rates to choose from. And you can buy them individually for if you want to change it up.
I personally run 375# up front and 250# in back. The 250# in back are pretty unbearable on bumpy roads lol. 375# is decent. I would say go with 300/200.
Old 09-16-2015, 06:05 AM   #9
Yeah but he has an On3 kit, I have not heard from On3 or anything solid on whether the On3 tubing will route past the MM K member or the MM Hellion K member. I know for sure the UPR works and he's likely going to be a straight line car with the turbo so the UPR is fine.
Old 09-16-2015, 07:07 AM   #10
I do drive it every day but I don't road race not care to. Lol I did look at the mm k-frame cause it's healthy but wasn't sure if I could use it.
Old 09-16-2015, 07:38 AM   #11
Then if you have the On3 and are just DDing the car get the UPR. That's what I would do anyway. But get the MM coilovers and CC plates.
Finally spoke to on3 performance fast 94 5.0 1979-1995 Mustang GT 11 07-01-2012 09:32 AM
On3 turbo fast 94 5.0 1979-1995 Mustang GT 11 06-27-2012 08:06 AM
On3 Turbo on 91 5.0 - follow up to 91 5.0 mostly stock thread JayKranz 1979-1995 Mustang GT 29 04-28-2012 09:33 PM
On3 Performance ColeJohnson 1996-2004 Mustang GT 43 12-29-2011 05:56 AM
On3 performance good bad??? Jose08 1996-2004 Mustang GT 0 09-09-2011 05:51 PM
02:06 PM
