Rear wheel size - Mustang Evolution
Old 09-15-2015, 02:20 PM   #1
Rear wheel size
So I have (4) brand new 275-40-17 tires that are on Cobra R wheels. I want to get a set of staggered bullit wheels and prefer to use the new tires I have instead of buying yet another set of new ones.
My question is am I able to fit my hankook tires on a 17x10 rear wheel without problem? Once those tires wear out, I'll be putting on 315's but want to see if this will work so I don't kill the wallet.
Thanks,
Josh
Quadracer18 is offline   Reply With Quote
Old 09-15-2015, 03:43 PM   #2
Mile high JDF's Avatar
They will fit but will have a slightly stretched looked to them
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-15-2015, 07:31 PM   #3
Steve96's Avatar
They will work fine on there. I have 275 40s on a 17x10 rear wheel. They are slightly stretched but actually look good IMO. Not like the hella flush guys or anything near that, just a little stretched and more of a slight angle to the sidewall instead of straight up and down. If it were me i would do exactly what you said in your post so your not wasting money. Only down side is you dont get much in the way of a lip to protect it from possible curb rash.
1996 GT
Old 09-15-2015, 07:33 PM   #4
Steve96's Avatar
Not the best detailed pic but you can see they look fine. At least they do to me anyway (i usually agree with myself most of the time)
1996 GT
Old 09-15-2015, 08:29 PM   #5
Depending on the brand they will fit perfectly or he a little stretched. My old 98 had BFG 275s on 10 wide and they had a nice slight bulge. Nittos would be very stretched. Use tireracks specifications section of your exact tire to get the section and tread width to see how wide they are.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 09-15-2015, 08:35 PM   #6
Steve96's Avatar
Scotty- im going tomorrow to get 245 45 17s put on my fronts, i want the front a little taller to fill more gap. Currently i have 255 40s on the front and they look a hair to small to me. I know the 245 45s are close to 3/4" taller than my 255s is this worth it or not? The 255s are 25" tall the 245s are 25.7" tall, im putting them on a 9" wide wheel too. Also the 245s are 2" bigger in circumference so overall fill more fender gap. My original plan was to move my 275s up front and get the BFGs in a 275 in the back but if the 245s will do the trick then it will be cheaper and their in stock locally. Just looking for an opinion as i know you have a ton of knowledge as far as tire sizes and what works and what doesnt.
1996 GT
Old 09-16-2015, 06:17 AM   #7
245/45/17 is the OEM size on 17x8 factory rims. 255/40 is way too short, 25" tire probably looks ridiculous up front especially if you are not lowered yet. A 245 will fit a 9" wide rim too but just barely. Again, depends on the brand. A BFG Comp 2 Sport will run a little wide so if you are worried about fit, get one of those.
Old 09-16-2015, 09:47 AM   #8
Steve96's Avatar
My car is lowered on H & R supersports, so its not as bad looking as it would be stock but have always seemed a little small to me. Im going to get a set of 245 45 17s for the front, this way they will be OEM height and the same height as my rear 275 40s are. The 3/4" or so height increase along with a overall 2" larger circumference will look better and fill the wheel well up a little more. Thanks for the input. Anyone looking for some slightly used 255 40 17 tires let me know, lol.
1996 GT
what size rims and what size slicks for 2005 GT? inzain Mustang Wheels & Tires 3 11-30-2013 08:37 PM
Smallest rear wheel size rebeltx 2011-2014 V6 Mustang 1 03-10-2013 11:12 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
Rear wheel and tire size poloka 2011-2014 Mustang GT 11 07-27-2011 07:44 AM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
04:34 PM
