Hanging RPMS - Mustang Evolution
Old 09-15-2015, 05:37 PM   #1
Hanging RPMS
Hey guys, I'm new to this page. I could use some help diagnosing my problem with hanging rpms. My 2004 GT had rarely done this so I never paid attention to it. Recently I just installed a BBK 78mm TB/Plenum and my rpms are hanging really bad. I will take it out of gear coming to a stop sign or red light and my rpms stick at 1500rpm and slowly drop down to normal idle when I'm at a complete stop. My car is also Bama tuned but I do not believe the tune is causing this. What could it be?
Vaughan1023 is offline   Reply With Quote
Old 09-15-2015, 06:48 PM   #2
Kris.R's Avatar
I have the exact same TB and BBK is known for the throttle plate sticking. The reason why your RPM's hang is because the vacuum of the throttle plate isn't adjusted correctly. Did you adjust the throttle screw?
2001 Mustang GT Conv. - JLT CAI - BBK 78MM TB - Magnapack Mufflers - Catted X-Pipe - 4.10's (Trac-Lock) - Steeda Underdrive Pulleys - BAMA 91 tune - Steeda Tri-Ax SS - Centerforce Stage II - Eibach Pro-Kit - Koni STRs - Saleen Rep Wheels - 275-35-18 F - 315-30-18 R
Kris.R is offline   Reply With Quote
Old 09-15-2015, 07:05 PM   #3
keeney35's Avatar
Mine did it too, just make sure your vac lines are seated right.. Not a big issue, easy fix
keeney35 is offline   Reply With Quote
Old 09-15-2015, 07:12 PM   #4
What exactly is my throttle screw? Sorry I'm not too knowledge on stuff like this.
Old 09-15-2015, 07:27 PM   #5
Slater2111's Avatar
Throttle screws are set from the factory. Don't mess with them! Or you'll screw yourself. They ain't like a throttle screw on a carb!
Slater2111 is offline   Reply With Quote
Old 09-15-2015, 07:41 PM   #6
I didn't touch anything like that. But if that's what's causing my hanging rpms then shouldn't it be adjusted? I've read where I may need to adjust my TPS voltage but I'm not sure how to do that.
Old 09-15-2015, 07:49 PM   #7
keeney35's Avatar
It should just be the vac lines if you didn't touch anything else
Old 09-15-2015, 07:52 PM   #8
So what should I do to fix it?
Old 09-15-2015, 08:27 PM   #9
Kris.R's Avatar
Go to post #9
Throttle body screw - Ford Mustang Forum
Your vacuum lines have nothing to do it with it. BBK is known to not machine the bore of the TB where the plate is housed properly. Just search on google and you'll find TONS of threads from different forums about your issue.
The whole "factory setting" for the throttle plate isn't something to be religious about as there can always be a simple error in assembly that could cause your issue. It never hurts to check.
As far as adjustment goes, when you look at the top of your TB you'll see the screw. Get a feeler gauge in there and check for proper clearance
Ex.
http://www.vtcoa.com/forums/attachme...e-photo-1-.jpg
Old 09-16-2015, 03:27 AM   #10
fenixignition's Avatar
did you pull your battery to reset your computer? because the sudden change in airflow will confuse it.
2002 GT 5sp. 16x,xxx miles
Old 09-16-2015, 07:34 AM   #11
Site Sponsor
Hey Vaughan1023 - Welcome to MustnagEvolution. Sorry to hear that you're running into trouble. I'd have to side with the rest of the fellas in here and I would start right with the throttle intake.
If this were a cold air I would start by hunting for a loose line but what's happening isn't in direct relation to the problem at hand and you're going to need to take a look at your tps.
This is a super, super common issue and the link for the post below should get you set up.
If you're having any trouble with this shoot my customer service team a call and they're happy to get you some help.
Let us know how you make out.
Alex
Go to post #9
Ex.
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 09-16-2015, 11:45 PM   #12
Kris.R's Avatar
Hope it all worked out Vaughan.
Old 09-17-2015, 07:33 AM   #13
Thanks guys. I think I've solved it actually. My IAC Valve is faulty. I have a tuner that clears my CEL so I forgot I could check codes. I'm pulling a faulty iac code and tps code for low voltage. Once again, thanks for all your help!
Old 09-17-2015, 07:21 PM   #14
Kris.R's Avatar
Awesome! Glad it was resolved.
Rpms hanging bad after battery reset Slow4V 1996-2004 Mustang GT 2 05-18-2014 06:29 PM
Rpms hanging while shifting blackstang4.6 1996-2004 Mustang GT 2 05-15-2014 08:07 AM
Rpms hanging Slow4V 1996-2004 Mustang GT 7 05-10-2014 06:18 AM
RPMs hanging fix? calebnaasko 1996-2004 Mustang GT 5 07-10-2013 10:14 PM
08:22 AM
