Labor Cost for Clutch Replacement - Mustang Evolution
Old 09-16-2015, 12:05 AM   #1
***I am having my clutch replaced with all parts provided.
-Can someone tell me the total cost just for the Labor?
~Parts supplied will be clutch kit, flywheel, FRPP throw out and pilot bearings, throw out bearing sleeve, clutch fork, clutch fork adjustable stud bolt, MM clutch cable kit, and cable heat shield.
-What was your labor only cost?
My first quote was $650.00
Ford will provide labor cost tomorrow
Thank You,
-Robb
Old 09-16-2015, 03:17 AM   #2
fenixignition's Avatar
its a lengthy process, so i would imagine the 450 to 650 range. also, everyone is gonna tell you to ditch the frpp throwout for an actual ford oem bearing. apparently the frpp's die out fast like any of the other aftermarkets.
2002 GT 5sp. 16x,xxx miles
Old 09-16-2015, 05:06 AM   #3
I just got finished installing a clutch on mine and I can tell you that it's nothing you can't do yourself. My car is a 98 with the T-45 and my throw out bearing was toast, clutch fork had a broken throw out bearing retainer and my stock clutch friction surface was just about completely gone. The t-45 already has a steel bearing sleeve on it but if you have a T-5 then you definitely need to upgrade to the steel version. I'd highly recommend doing it yourself and saving the money for other things because outside of removing the rusted exhaust hardware and the starter it's really not hard at all. I decided to get a ford racing flywheel and the spec stage 2 clutch and I love it. I don't recommend getting an aftermarket clutch cable or anything like that, but a billet clutch quadrant is a good idea because the plastic one could break. I suggest doing a fluid swap also while you're in there because it's good cheap insurance.
Old 09-16-2015, 06:33 AM   #4
If my dad and I can do it in 3.5 hours on a lift from start to finish with hand tools and stopping to have hamburgers, no reason a good shop can't do it that fast. I wouldn't pay more than 4 hours of labor no matter what they try to quote.
Old 09-16-2015, 01:09 PM   #5
Thank You,
-Robb
flat rate should be 4.5 hrs X their labor rate,run from the place that quoted $650. my 19 year old grandson with no experience did it in 4 hr by himself. made him so he would take better care of this one
ALLYDRIVER1 is offline   Reply With Quote
Old 09-16-2015, 01:30 PM   #6
The world needs more of this.
Sent from my SM-G920V using Mustang Evolution mobile app
Old 09-16-2015, 01:38 PM   #7
Jbone007's Avatar
Agree!!!!!
Jbone007 is offline   Reply With Quote
Old 09-17-2015, 09:08 AM   #8
Panther140's Avatar
Clutch job on these is SO easy. I replaced a clutch on my 99 GT in under 4 hours in my back yard on small jack stands.. Laying on my back in the grass lol. I was 19 and my dad wouldn't let me do it in the garage.
hell, he only let me 'borrow' one bay in his garage for precisely 4 days to do an engine swap when I was in college the winter before that. Got it done! Basic hand tools and jack stands is all you need
Only thing I would take my car to the shop for is brakes. I hate working on brakes and its usually not much money to have them do it.
Panther140 is offline   Reply With Quote
Old 09-17-2015, 10:25 AM   #9
I have a really hard time believing that you are ok doing a trans change on your back in the grass but don't want to take the 2 hours total to do brakes on all 4 corners... like... Eh, whatevs. Brakes are so damn easy to do on most cars, the only time it sucks is when the tires haven't been rotated in forever and the rotor or drum is stuck. And then a BFH and a block of wood usually does the trick.
Old 09-17-2015, 11:12 AM   #10
Panther140's Avatar
I know how to do brakes...
I think you must have miss-understood me when I said that I "hate" doing brakes.. Boring and rusty and it just takes all day lifting the car up with my frakin scissor jacks just do mess with something and then realize I need to go get another stupid bleeder nipple because the one on the caliper was 100% decayed ****.
It takes more of my time than its worth. Shops can do brakes faster than me-- they have a hoist and its cheap enough for me to not mess with it on my own time.
Old 09-17-2015, 11:20 AM   #11
yea. easier to afford a brake job than a clutch job.
but id still be doin my own brakes, rusty or not. course, when i got my car, i had to change the calipers anyway, so i had the luxury of a few new parts. I almost changed the bracket, but i couldn't get the bolts off. didn't have as many tools then as I do now. Kinda wish i switched em though. 160k old rusty brackets are quite unsightly.
Old 09-17-2015, 11:21 AM   #12
Gotcha. I have a power bleeder and a bunch of tools and a quick lift jack and I also don't trust shops to touch anything I own.
Old 09-17-2015, 11:27 AM   #13
Panther140's Avatar
True that. I don't let them touch any of the important stuff.
Old 09-17-2015, 11:44 AM   #14
natestang07's Avatar
Would you fellas do a cam replacement on this engine?
Old 09-17-2015, 12:09 PM   #15
I dunno about a cam but I bet a CAI would add at least 800 horsepowars.
Old 09-17-2015, 12:10 PM   #16
Safe to say that thing is a torque monster?
Old 09-17-2015, 12:11 PM   #17
Nah, no VTEC.
Old 09-17-2015, 12:13 PM   #18
I want to see the machinery used to build something that massive
Old 09-17-2015, 12:15 PM   #19
Massive machines lol, but what builds THEM? Where does it stop!?
I watched a show on motors like this, apparently the cylinders have access hatches and they can be shut down individually for maintenance while the motor is running.
Old 09-17-2015, 12:31 PM   #20
cherry picker,10,13,15, mm wrench 5 lb hammer. what more do you need?
Old 09-17-2015, 12:41 PM   #21
I would assume stuff a lot bigger than that lol
Old 09-17-2015, 08:55 PM   #22
I can't imagine being inside one of those cylinders knowing that the rest of the engine is still running.
Old 09-17-2015, 08:56 PM   #23
Sounds terrifying
Old 09-18-2015, 12:32 AM   #24
Thanks for info.
Second price from Ford was $720.00
Waiting on third price from a Mustang/Speed Shop locally.
I live in a condo and they feed me **** for working on the car all the time.
~I will let shop install clutch
~My bro-in-law is a mechanic and he will be helping me with the new exhaust system and installing the Brembo package, the stainless steel brake lines, & the complete caliper rebuild kits.
I still have lowering springs, shocks/struts, X2 balljoints, bumpsteer kit, & caster camber plates to install also.
With a huge *** family as we have, someone is ALWAYS parked in his garage working on a vehicle.
Old 09-18-2015, 03:04 PM   #25
joking here^^^
Old 09-19-2015, 08:58 PM   #26
alecas447's Avatar
250-300 down here
alecas447 is offline   Reply With Quote
Old 09-19-2015, 09:41 PM   #27
5-6 hours labor around here.
I don't care how easy or difficult it may be to install, i am mostly concerned with quality craftsmanship. Shops that work on Mustangs daily give me an extra piece of mind. That makes sense, right? They are quick with their work because they have done it many times over. While parts are disassembled, sometimes other issues are discovered, and I've had some free extra parts & work thrown in while working on the car.
NOW I NEED TO KNOW WHICH MOTOR STARTER TO PURCHASE.....OEM? Which kind & why would help me.
Thank You All AGAIN!
-Robb
Old 09-20-2015, 04:14 AM   #28
OEM because you want it to last, since changing it again means using like 3 feet in extensions just to get one bolt.
The the 98 and under had that same problem, right? Or is that just a 99 04 thing?
Old 09-20-2015, 03:55 PM   #29
5-6 hours is what they may charge. It will take them half that time tho.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 09-20-2015, 06:54 PM   #30
Yeah, waiting on last price quote from a "speed shop" down the road a bit. They are quoting me full suspension installation/bumpsteer alignment pricing too.
~Spent today dying the steering wheel black.
~Using 3M leather/vinyl repair kit for the first time too, on the drivers seat. I may dye the seats "two toned" Saddle/Black.
~Installed LED's in the rear view mirror.
~Covered the cooling cross over pipe in front of alternator with new thermal wrap. Wrapped the top of each exhaust down pipe closest to manifold too.
*~I have a new instrument panel, new "ruby red/reflective" SVT decal for above RPM gauge, odometer gears, and warm white LED's for instrument gauges and AC/Heat panel. That will freshin things up a bit, brighter/crisper looking gauges will be nice.
Old 12-17-2016, 01:06 PM   #31
Region: Iowa
quote from trans shop
web said 3.1 hours to replace clutch assy
trans shop quoted 5+ hours plus $165 kit w/o discount
I countered 3hrs @ shop rate plus price of kit...they refused.
Is there something else I don't know about that takes 5hrs???
Gary
gary9alan9 is offline   Reply With Quote
Old 12-17-2016, 01:10 PM   #32
Region: Iowa
my Ford dealer doubles the flat rate times. Gary
Anybody know the cost of 03-04 cobra eaton supercharger porting cost? larrysgt 1996-2004 Mustang GT 1 05-08-2014 06:58 AM
Dyno cost? Tune cost? The420fox 1979-1995 Mustang GT 17 02-22-2013 01:10 PM
$630 Labor cost?!?! 02Nate281 1996-2004 Mustang GT 18 10-24-2010 03:26 PM
Cenla MONDAY Sept 7th Labor Day Autocross, MONDAY, MONDAY, MONDAY, LABOR DAY SEPT 7th DarkShadows Regional Mustang Discussion 20 09-08-2009 11:24 AM
Average cost (clutch & labor) cagedthought Pre-2005 V6 Mustang 7 03-24-2005 08:08 PM
04:37 PM
