Complete Parts List For 20 year old clutch - Mustang Evolution
Old 09-18-2015, 04:44 PM   #1
Can you tech heads/mechanics tell me what is found worn out or busted when car is up in the air ready for a clutch replacement?
I do not want to just replace a clutch kit and T/O & pilot bearings.
Thank You
Old 09-18-2015, 04:55 PM   #2
fenixignition's Avatar
maybe the transmission output seal. rear axle seal since the driveshaft is off. 02 sensors if you never get underneath it. rear main. change tranny fluid. check your oil pan gasket for leaks (requires removal of k member)
2002 GT 5sp. 16x,xxx miles
Old 09-18-2015, 08:18 PM   #3
Thank You, I think I have everything covered on that end.
Old 09-18-2015, 08:31 PM   #4
Re-surface or replace flywheel?
Old 09-18-2015, 08:35 PM   #5
Panther140's Avatar
Things to do when the car is on the hoist:
-Clutch Fork
-TOB Sleeve
-Flywheel resurface
-Check Trans input shaft for abnormal play (not all play is abnormal IIRC)
-Remove/replace ANY AND ALL rusty bolts that you can get at under the car. I h8 rusty boltz so just do it for me :p lol
-Starter and/or solenoid. At least put corrosion protection on the connections
-Inspect Brake lines
Panther140 is offline   Reply With Quote
Old 09-18-2015, 09:50 PM   #6
TOB sleeve is one that might need doing but might not, depends on the shape its in and the mileage. The 96-98 T45s do not age well internally or externally so hopefully yours is in decent shape.
Otherwise:
-New Pilot bearing
-New TOB
-New Flywheel
-Good clutch like an Exedy Mach 400
That's really all that there is unless you need to do your rear main.
Old 09-19-2015, 04:16 PM   #7
scottydsntknowTOB sleeve is one that might need doing but might not, depends on the shape its in and the mileage. The 96-98 T45s do not age well internally or externally so hopefully yours is in decent shape.
Otherwise:
-New Pilot bearing
-New TOB
-New Flywheel
That's really all that there is unless you need to do your rear main.[/QUOTE]
Panther140 Things to do when the car is on the hoist:
-Clutch Fork
-TOB Sleeve
-Flywheel resurface
straybullitt Re-surface or replace flywheel?[/COLOR]
[/COLOR]
Thanks A Million!
~I have McLeod clutch, McLeod flywheel,FRPP TO & pilot bearings, MM clutch cable kit, throw out bearing retainer tube, clutch fork pivot ball stud, FRPP clutch fork.
~Have a new BREMBO package(rotors, pads, ect) with stainless brake lines and complete rebuild kits for all 4 wheels.
THANKS!! I WILL HAVE a starter replaced, trans input shaft checked for play, you guys helped in a HUGE way. I really appreciate it, means alot to me, Thank You, -Robb
Complete build list... 2013 Green GT 2011-2014 Mustang GT 2 09-18-2012 03:11 PM
Complete list of Spring ratings Danger Dude Pre-2005 V6 Mustang 1 03-07-2011 05:45 PM
Who Would You Vote For. Complete List (As of now) Brent The Bar 22 10-02-2008 11:21 AM
ford is sketchy...funny year to year changes tedness The Bar 15 08-14-2005 08:28 PM
List of accomplishments in Iraq 1 year later Danger Dude The Bar 12 03-20-2004 02:33 PM
08:13 AM
