Camshafts - Mustang Evolution
Old 09-19-2015, 10:37 AM   #1
Saleen2003's Avatar
Camshafts
Im planning to buy Camshafts XE274H stage 4...Is it ok to put those in a stock 4.6 engine without changing the springs?? And what about long term reliability??Is it safe?
Sent from my iPod touch using Mustang Evolution
Saleen2003 is offline   Reply With Quote
Old 09-19-2015, 10:54 AM   #2
drew416's Avatar
On a stock motor I believe you'll have PTV issues. Probably not the safest.
2003 mustang gt "slowleen"
drew416 is offline   Reply With Quote
Old 09-19-2015, 11:16 AM   #3
Saleen2003's Avatar
I've heard that the 99-00 used different pistons than the 01-04...Im affraid damaging the engine...
Old 09-19-2015, 04:44 PM   #4
retiredvet's Avatar
*edited* I double checked the specs. I was wrong. You will have no PTV clearance problems but you will need new valve springs. With only a .500 lift the cam should be good for the 2k-6k it claims. Not a huge fan of comp cams myself I'd suggest crower stage 1 over this 'stage 4' cam personally.
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 09-19-2015, 08:54 PM   #5
keeney35's Avatar
For sure use the beehive springs!!! They are a must, I just did the comp 270's and they had to check piston to valve cause they were close.. Might have to even ****** the timing for 274's
keeney35 is offline   Reply With Quote
Old 09-19-2015, 09:17 PM   #6
retiredvet's Avatar
your 270's have more lift than the 274's. by quite alot(quarter inch) in fact. Your 270's have more extreme lope and idle. his 274's are only .500 lift so its an easy fit
Old 09-19-2015, 09:26 PM   #7
keeney35's Avatar
I thought they were more radical? Stage 3 to his stage 4..
Old 09-19-2015, 09:30 PM   #8
retiredvet's Avatar
it all comes down to duration and lobe seperation. His stay open longer and are on a narrower lobe seperation. His idle is smoother but flows more air overall. More of a blower cam. A N/A cam opens wide but briefly.
Old 09-19-2015, 10:08 PM   #9
keeney35's Avatar
Which gives the more choppy idle correct?
Old 09-20-2015, 12:04 AM   #10
retiredvet's Avatar
Yes the wide quick open close is what gives you the lope
Sent from my LG-D415 using Mustang Evolution mobile app
Old 09-20-2015, 06:12 AM   #11
keeney35's Avatar
By god I'm learning something lol
Old 09-20-2015, 10:09 AM   #12
Panther140's Avatar
Slower lift rate with more valve overlap accounts for a good chunk of what makes certain cams sound good.
You know those old school V8s with flat tappet cams? That's one of the reasons for the old school sound. They had to run slow lift rates. They could have the peaks of the lobes be separated pretty far out and still have valve overlap for days
Panther140 is offline   Reply With Quote
Old 09-20-2015, 10:39 AM   #13
Panther140's Avatar
Ehh, valve overlap is more of the central topic.
Modern engines all have really steep cam profiles. Steep cam profile is actually why modern engines DONT lope like the old ones. The engines have more static compression because of this. The valves don't overlap as much anymore.
Think about the ghost cam tunes. All those do is add valve overlap with the stock cam's lift and duration, but it still chops pretty good. It would chop even more if the cam profile was more gradual, so there was more valve overlap.
Lift and duration definitely are factors in how choppy it sounds-- because those increase the valve overlap and decrease the static compression even more. the eccentuate the phenomena that makes it lopey
Old 09-20-2015, 02:48 PM   #14
retiredvet's Avatar
Well I tend to keep things on the k.i.s.s. level when helping people learn the fundamentals
2005-2009 Comp Mutha Thumpr camshafts. Graham1992 Mustang Parts for Sale and Wanted 12 12-02-2012 10:50 AM
anyone install FR Camshafts? redfire 2005-2010 Mustang GT 15 10-12-2012 11:55 AM
2011 V6 Camshafts?? ChrisMustangs 2011-2014 V6 Mustang 14 09-30-2012 11:49 AM
Camshafts?! tea84 2011-2014 Mustang GT 9 02-06-2012 06:49 PM
O4 3.9 v6 mustang camshafts? Zebs5408 Pre-2005 V6 Mustang 2 10-04-2009 01:54 PM
01:44 PM
