Me or the tires? - Mustang Evolution
Old 09-20-2015, 07:04 PM   #1
Jheard517's Avatar
Me or the tires?
I bought 315 17 35 nittos and having a hard time heating them up.
Jheard517 is offline   Reply With Quote
Old 09-20-2015, 07:05 PM   #2
Rapinator126's Avatar
Which ones?
🍼and 🌽 fed coyote.
Old 09-20-2015, 07:32 PM   #3
Jheard517's Avatar
555r
Old 09-20-2015, 08:02 PM   #4
retiredvet's Avatar
It takes more to heat them up vs other brands but stick better than most once heated
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 09-20-2015, 08:05 PM   #5
alecas447's Avatar
Me or the tires?
I have the same tires havent had an issue
alecas447 is offline   Reply With Quote
Old 09-20-2015, 08:09 PM   #6
They honestly do not need to be heated. A quick spin and they should be ready to go.
I'm not a fan of the 555rs for a actual drag radial. They do good, and can be ran year around and in weather ect, I consider them more of a DD tire.
Just give them a quick spin like I said and you will be good.
I have ran the tires more than once.
If your looking for a drag radial to actually stick you need to look at M&H, MT , or the nt05r from nitto.
🍼and 🌽 fed coyote.
Old 09-20-2015, 08:21 PM   #7
Jheard517's Avatar
Thanks. Im gonna keep the nitto for the street. Is it true that manual cars have a harder time with a drag tian a slick?
Old 09-20-2015, 08:26 PM   #8
Yes. If you are at the actual track then you will do better with a slick.
You can break a axle with a drag radial.
Just use the 555rs for your DD tires and then get a different set of rear wheels with a slick, for the track
🍼and 🌽 fed coyote.
Old 09-20-2015, 08:55 PM   #9
Panther140's Avatar
Daily drives with slicks
Panther140 is offline   Reply With Quote
Old 09-20-2015, 09:46 PM   #10
Jheard517's Avatar
Good deal. Thanks
Old 09-21-2015, 10:25 AM   #11
Byock's Avatar
Region: Utah
Rap, what slick would you recommend for the MT-82?
Byock is offline   Reply With Quote
Old 09-21-2015, 10:39 AM   #12
I ran the M&H slicks for a short time.
Also ran the M&H drag radials also. Which is built like a slick. Only downside to the drag radials is they will get a flat spot just like a slick if it sits on the ground for a couple weeks on the car.
🍼and 🌽 fed coyote.
Old 09-21-2015, 10:41 AM   #13
Byock's Avatar
Region: Utah
Awesome, thanks! I plan on just putting them on the car at the track.
Will 205/75-14 tires fit 14x7 wheels? will 225/45-17 tires fit 16x8 wheels? baudier Classic Mustangs 4 03-29-2016 08:25 PM
Tires Tires!!! Nathan69 2005-2010 Mustang GT 17 01-04-2011 01:43 PM
I need tires and rims for my 1990 Mustang. But I want the tires to be shipped ON the rims.? nahcomence Mustang Wheels & Tires 5 04-02-2010 01:06 AM
cobras/tires for welds/tires, $$$? tire The Bar 2 02-22-2004 11:11 AM
12:17 PM
