Water leak ? - Mustang Evolution
Old 09-22-2015, 08:20 AM   #1
Water leak ?
Last night in the process of painting the hood I was just curious popped off the resivor cap and there was nothing there so I filled it up with water and waited a second so see if I could visually see a leak but I've noticed it only does it when running ?
Also a friend mentioned while he was behind me when I shifted from 3-4 there was a cloud that came out the exhaust pipe.
Any suggestions are appreciated
Skax is offline   Reply With Quote
Old 09-22-2015, 09:29 AM   #2
fomoco4life's Avatar
Sounds like possible head gasket issue, and I believe u should never use straight water, always use diluted pure or prediluted antifreeze. A compression test should let you know how your gaskets are doing
Old 09-22-2015, 09:49 AM   #3
parkerz28's Avatar
I would check the back of your intake manifold. There is a nipple that comes off the intake manifold made of plastic that goes into the heater core. Those break with age and is a common problem. Would also only leak when running.
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 09-22-2015, 10:00 AM   #4
I'm running out there now ganna check the oil see if it's milky and check the nipple on intake that's what broke last time it's a new intake though
How do I get rid of hard water marks/sprinkler water marks? HooniganGT5.0 Mustang Paint, Appearance & Detailing 18 12-08-2014 07:37 PM
Water Leak Kick Panel Area ThatsCoolBro 2005-2010 V6 Mustang 1 04-06-2013 11:20 PM
Anyone have a water leak? Mandy4 2011-2014 Mustang GT 48 08-25-2012 03:44 PM
Water leak! Pete08GT 2005-2010 Mustang GT 19 04-16-2011 01:50 PM
09:29 PM
