Squeaking shocks - Mustang Evolution
Old 09-22-2015, 11:27 AM   #1
cozny's Avatar
Squeaking shocks
So recently; I've noticed this annoying squeaking noise coming from my trunk. So further on inspection I found out it's coming from one of my new koni oranges. What's surprising is only one of them squeaks. The right side doesn't squeak, but the left side does. It sounds like it may be the rubber bushing that's connected to the upper shock mount. Thanks for any input!
cozny is offline   Reply With Quote
Old 09-22-2015, 11:40 AM   #2
Strange Mud's Avatar
I've seen a few people complain about the oranges squeeking.
Old 09-23-2015, 04:45 AM   #3
fenixignition's Avatar
pull it out and grease up or change the bushing. you might get away with spraying it with a can of oil of your choice. your sure its not your coil spring insulators?
2002 GT 5sp. 16x,xxx miles
Old 09-23-2015, 08:31 AM   #4
cozny's Avatar
Ya, I'm going to just too pull it out Tuesday. And put some all weather grease in between the bushings, and I'll see how it goes. Thanks for the input guys.
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 01:03 AM
To get rid of squeaking... crazeflier07 Pre-2005 V6 Mustang 0 08-08-2007 08:14 PM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 09:38 AM
Car Squeaking Over Bumps/Hills/Rolling Roads Shahrum Pre-2005 V6 Mustang 12 03-03-2004 08:47 PM
can't stop doors from squeaking stangracer Mustang Audio & Video 11 11-11-2003 11:08 AM
01:15 AM
