Rear main seal !! - Mustang Evolution
Old 09-23-2015, 09:36 AM   #1
smsstang's Avatar
Rear main seal !!
How much would it cost to replace the rear main seal . Mustang is leaking a tiny bit and it annoys me . I'm thinking it might be the seal . Is it something that can be done in the driveway or would it be better to take it to a shop ? Thanks
smsstang is offline   Reply With Quote
Old 09-23-2015, 11:18 AM   #2
Transmission has to come all the way out. Try a thicker weight oil first IMO. 5w-40 works fine in a modular and no issues with cold starting either.
Old 09-23-2015, 11:26 AM   #3
smsstang's Avatar
Ok I will try that but how much is labor for that usually ?
Old 09-23-2015, 11:30 AM   #4
4 hrs labor,drop transmission and flywheel R&R seal
ALLYDRIVER1 is offline   Reply With Quote
Old 09-23-2015, 11:36 AM   #5
smsstang's Avatar
So probly 300$ to a shop ?
Old 09-23-2015, 11:39 AM   #6
No try $500-$600
For a $30 part...
Old 09-23-2015, 12:01 PM   #7
smsstang's Avatar
That hurts my feelings a little bit lol well luckily I work for a shop that has good contacts . Is there any brand seal that's recommended or does that not really matter in this case .
Old 09-23-2015, 12:20 PM   #8
Not really.
Again, I would try a thicker weight oil first. It could very well fix the problem. 20 weight stuff is like water...
Old 09-23-2015, 12:25 PM   #9
smsstang's Avatar
Okay I will try the 5w40 then this just happened recently after the oil change I got so I will go try that out .
Old 09-23-2015, 06:09 PM   #10
If they used a full synthetic oil, that can cause oil leaks on high mileage engines. Even synthetic "blends" can cause leaks. Synthetic oil can find it's way out of the tiniest little hole.
I would try a conventional oil and maybe use a 5W30.
Old 09-23-2015, 06:12 PM   #11
true that^^^^
Old 09-23-2015, 06:13 PM   #12
smsstang's Avatar
Yeah I used Mobil 1 synthetic . What good conventional oil do you recommend ?
Old 09-23-2015, 06:16 PM   #13
I have had the same problem with Mobil 1.
Try a blend first. I like Motorcraft.
Old 09-23-2015, 06:21 PM   #14
smsstang's Avatar
Like are you meaning half in half when you say blend ? And is motor raft a good brand to use ? It sucks cause the place o got my oil change at put the wrong stuff in then what I had ask them to put in it then out of no where starts leaking on brand new house drive way . Lol
Old 09-23-2015, 06:25 PM   #15
Yes. A blend is part conventional and part synthetic.
Motorcraft is a good oil...But almost any brand is good nowadays!
Simple Green works good on driveway stains.
Old 09-23-2015, 06:31 PM   #16
smsstang's Avatar
Okay sweet and yes I have simple green so I need to get to scrubbing and I guess I will get motorcraft conventional 5w30 thanks man
Old 09-23-2015, 06:38 PM   #17
No problem!
Try their Synthetic Blend first. Or something that says it is for high mileage engines.
If that doesn't work, then you can try a straight conventional.
Old 09-23-2015, 07:07 PM   #18
parkerz28's Avatar
That's a myth... Synthetic oils don't cause leaks out of conventional seals...
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 09-23-2015, 07:18 PM   #19
Are you saying that my real world experience, not something that I read on the internet, is incorrect?
Old 09-23-2015, 07:50 PM   #20
in a word bull****, put synthetic oil in a 100k car with no leak and will be leaking from every orifice with-in 100 miles
Old 09-23-2015, 08:44 PM   #21
No guarantees that changing the oil will solve the problem, but I would certainly give it a try before changing the seal.
I put about 3 quarts of Mobile 1 into my truck engine when it had around 300k on it. It started leaking almost immediately. I changed the oil back to Castrol High Mileage, which is a synthetic blend, and it stopped. That engine is still in my truck, with 410k, and no leaks!
I also had an airless paint sprayer powered by a Honda engine. On the very first oil change, I used Mobil 1, and it also started leaking almost immediately. I kept using synthetic in that little engine because it got used long and hard, with very little maintenance.
Also, OP, check the oil level and make sure that the crank case isn't over filled.
Old 09-24-2015, 05:01 AM   #22
parkerz28's Avatar
My formula firebird had over 200k on it all I used was mobile 1. No leaks my Camaro had 150k no leaks so they must of been ... Cough... Special I guess lmao
Old 09-24-2015, 06:34 AM   #23
What exactly is your point? You had two cars with good seals that didn't go bad. I'm not saying if you put synthetic in a vehicle with conventional after 100k it will always leak 100%... but if you have a vehicle leaking a little with syn and switch to a blend or regular dino... well I've seen that cure work myself personally IRL.
Old 09-24-2015, 07:10 AM   #24
parkerz28's Avatar
Old 09-24-2015, 10:12 AM   #25
and what was your point,doesn't make a lot of sense
Old 09-24-2015, 10:24 AM   #26
parkerz28's Avatar
I simply said you could run synthetic oil in a vehicle with over 100k miles and provided 2 examples from my own experience. I'm not sure what is confusing about it.
Old 09-24-2015, 11:02 AM   #27
Because it sounded like sarcasm.
Old 09-24-2015, 04:07 PM   #28
ddtmoto's Avatar
Region: Utah
Reseal AT-205 from ATP....works well. Amazon has it, I can't find it locally.
ddtmoto is offline   Reply With Quote
Old 09-24-2015, 11:04 PM   #29
Oh, Boy-
*Motorcraft Semi-Synthetic is an excellent oil, but doubt it would stop a rear seal leak.
*I believe that "High Mileage" oils are used with intention of only using it for a 3K-5K mile interval, drain, return to conventional oil and monitor.
*Don't use any oil additives that "Fix Oil Leaks".
*Check out BITOG for some educated opinions.
*Call local Mustang shop, and again, listen to Mustang experienced technicians opinions. Ask "What Causes This Particular Seal Leak" , if there is any, hereditary causes, that is... & what say you?-
Best O Luck!
I'll Be Monitoring This THREAD,
JUST MY
~Please Update, I wanna know what to do too.
Old 09-25-2015, 05:49 AM   #30
He said it was just a few drops. Going to a blend or a higher weight could band aid it for awhile. Hell, going 40 weight stopped a leaky cam seal on my wife's Honda and it hasn't come back for 20k...
Old 09-25-2015, 10:04 AM   #31
fenixignition's Avatar
gonna beat a dead horse here for a bit, but last i heard, which was from engineers at valvoline (possibly pennzoil) that the molecules in a synthetic oil are made the same size as ones in a conventional, and pretty much debunked that myth. The best ive always figured, is that synthetic oil has more detergents in them, and clean out the cracks filled with old buidup, thus, leaks. I know one of you said that you went from castrol, to mobil 1, and back to castrol, and experienced leaks only with mobil 1. all i know is that mobil1 is slightly thinner than castrol conventional. even if they are both 5w30. but its a minimal difference. cant really explain what happened there.
2002 GT 5sp. 16x,xxx miles
Old 09-25-2015, 01:46 PM   #32
I just use Rotella T6 in everything. 5w-40, super heavy duty oil, not too expensive and available everywhere. Motorcraft or WIX filter and call it a day.
Old 09-25-2015, 03:49 PM   #33
smsstang's Avatar
I will just try a thicker oil like Scotty is recommending and see what happens . If it continues then looks like I will just get the new seals
Old 09-25-2015, 06:36 PM   #34
Synthetic oil is more "slippery" than conventional oil...Especially when it is cold! Combine that with the first number in the recommended oil weight for our engines (5), and a seal that has had a crankshaft spinning around inside of it for tens of thousands of miles...And I am going to stick to my theory that synthetic oil will indeed find its way out of a seal that will not leak with conventional oil.
I'd be willing to bet that OP's engine does not leak a drop of oil while the engine is running and warmed up. It is when the oil is cold, and at it's thinnest viscosity, that it is leaking. Hence, the spots on his driveway.
Old 09-26-2015, 02:45 PM   #35
its actually thicker when it is cold. or more viscous for that matter.
it has the viscosity index of a 5 weight oil when it is cold, maybe even at freezing temp or 0F. as it warms up, the structure (at a microscopic level) changes, and has properties of a 30 weight. (or 20 or 40 or 50, whatever your using). the viscosity rating at 40C for mobil1 5w30 is 61.7, and at 100C its 11.7.
I am under the impression that the lower the viscosity level, the thinner the oil. please correct me if i am wrong. but that would explain why people say the oil flows better when your draining it if you warm it up first.
also just an fyi, 5w30 vs 5w20 at operating temp, i believe is 8. something vs 11.7. slightly thinner.
Rear Main Seal or Oil Pan Gasket leak? DutchManDann 1996-2004 Mustang GT 16 03-10-2015 08:42 AM
Rear Main Seal BigB227 1996-2004 Mustang GT 2 02-27-2012 05:27 PM
Rear Main Seal? ColeJohnson 1996-2004 Mustang GT 5 02-10-2012 07:39 AM
Rear main seal replacement? 90Stang_5.0 1979-1995 Mustang GT 8 11-18-2011 01:50 PM
Rear main seal jhagan1980 General Mustang Discussion 0 11-04-2011 07:09 AM
» Members Mustangs
Baby Blue
Dmay65
Kona
WhoDat
Add your Mustang
05:52 PM
