Power Windows on Passenger stopped working Help! - Mustang Evolution
Old 09-23-2015, 01:47 PM   #1
Unhappy Power Windows on Passenger stopped working Help!
Okay, So i have a 1998 Mustang Gt (manual, 4.6L, V8, 150,000 miles) and i have an issue with my (Passenger) window. My passenger window normally works with no issue, but if one of my friends sitting in my passenger seat decides to use the window, it will work for as long as I'm driving car. But once i stop and turn car on again and try to put window down with either driver window button or passenger window button it wont go down anymore. Normally i just wait about 3 days and it just magically starts working on its own again. But now its been a month and my window wont go down anymore. This has been going on for past 2 years since i have had the car so its nothing new but now since it stopped working completely i need to get it fixed. i cant imagine it being a fuse since my driver window works perfectly. I also don't think its the motor because when it wanted to work it went up and down with no problem (no noises, went up and down fast). I'm thinking there might be a short somewhere?
Nramos20 is offline   Reply With Quote
Old 09-23-2015, 05:50 PM   #2
If I had to guess, I'd say that the lift motor is bad.
Try banging on the door panel and see if it makes it work again.
You are going to have to remove the door panel, at some point. When you do, you can check to see if there is power going to the motor when the switch is engaged. If there is power, the problem is the lift motor.
Old 09-23-2015, 06:23 PM   #3
slam the door works too,old ford trick,sorry motors are still same as in the 80's. the problem is the spring behind the brush have fixed many by adding a ballpoint pen spring inside stock spring
ALLYDRIVER1 is offline   Reply With Quote
Old 09-23-2015, 06:29 PM   #4
Since you live in Orlando, if you don't mind a trip to the Melbourne area, I have a guy I have used for 20 years or so...he or his wife come to you.
12Volt power window 321.213.3002
Typically less than 1/2 the price of shops.
rsc0155 is offline   Reply With Quote
'90 LX - all four power windows stopped at once BossDrew 1979-1995 Mustang GT 14 09-05-2015 01:19 PM
Driver power window stopped working etihw 1996-2004 Mustang GT 5 08-10-2015 12:08 PM
radio randomly stopped working it seems to be wireing any help The420fox 1979-1995 Mustang GT 8 06-04-2013 12:27 PM
gas gauge stopped working! please help! ugafan_1207 1979-1995 Mustang GT 18 01-14-2011 12:18 AM
Passenger Side Power Window Not Working louie7600 General Mustang Discussion 1 07-27-2008 07:36 PM
10:57 PM
