Motor bay - Mustang Evolution
Old 09-24-2015, 01:36 PM   #1
joe_117's Avatar
Motor bay
So any good products to clean your motor? Also things to avoid when cleaning?
joe_117 is offline   Reply With Quote
Old 09-24-2015, 03:48 PM   #2
retiredvet's Avatar
Old school car show prep: at the car wash let engine cool, spray off grime, switch to tire cleaner and hose down entire engine and bay, let sit, rinse well, drive to detail spot and spray engine down with armor all tire wetter, close good and leave car running to let "bake" about 15 min u can start any hand wiping u need
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 09-24-2015, 05:51 PM   #3
joe_117's Avatar
I wont have to worry about my coil packs?
Old 09-24-2015, 07:46 PM   #4
retiredvet's Avatar
I do this to all my cars, if it cant take a bit of hosing then screw it its not worth owning. Never had a problem. But I dont go insane with the high pressure wash. Wash,cleaner,rinse,dry,wetter,bake and you can stop there unless ur hand polishing for show
Old 09-24-2015, 10:50 PM   #5
Steve96's Avatar
Ive used this method before and it works very well. Clean it from time to time, avoid dirt roads, then you can just touch up the armor all or whatever you use and it will look good for a good while. I think a lot of used car dealers do this as well. The only issue is that sometimes the tire foam or whatever you use can become a dust magnet
1996 GT
Old 09-25-2015, 12:53 PM   #6
I spray the engine compartment with Simple Green and then rinse it with a spray from the garden hose.
There is a diagram in the care and maintenance section of the owners manual that highlights the areas to avoid getting wet.
Old 09-25-2015, 02:16 PM   #7
XSlashDashX's Avatar
Our dealership I work for use a pressure washer for the engine bay then use tire shine.
Old 09-30-2015, 06:18 AM   #8
fenixignition's Avatar
A lot of dealerships do that. I just read a can of wd-40, it was a big can with the wide spray nozzle. that suggested spraying it in the engine bay to drive out moisture and protect from corrosion. anyone hear about doing this or tried it?
EDIT: just did some research online. sounds more like a bad idea. especially when it drives the moisture out of plastics and hoses. apparently it was only good for keeping water out of a distributor. i almost thought it would be great for electronics on the engine, but apparently the opposite.
2002 GT 5sp. 16x,xxx miles
Old 09-30-2015, 12:03 PM   #9
GHO5T5NIPER's Avatar
After blowing the engine in my 4runner to water, it scares the hell out of me to get water anywhere near the engine bay on the mustang lol. I resorted to a toothbrush, a spray bottle, a duster, and some engine degreaser lol
GHO5T5NIPER is offline   Reply With Quote
Old 09-30-2015, 12:35 PM   #10
joe_117's Avatar
Same...
Old 09-30-2015, 05:45 PM   #11
Yea a spray bottle of water to rinse with is safest.
Sent from my SM-G920V using Mustang Evolution mobile app
blown 99 gt motor puting in a 2000 gt motor derrickk 1996-2004 Mustang GT 9 07-12-2015 12:05 PM
F.150 5.0 motor and 5.0 mustang motor Bpolley11 1979-1995 Mustang GT 11 05-27-2013 12:03 PM
motor bay thread 01bullitt 1996-2004 Mustang GT 39 08-18-2012 09:07 AM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
02:28 AM
