Need help with p1151 code. - Mustang Evolution
Old 10-01-2015, 12:03 PM   #1
I buy and flip cars all the time and I am used to them having check engine lights and little issues but prepare myself to fix them before selling them on. But I bought this 1998 GT and it didn't pop a check engine light until after I had driven it for almost a week. It's a p1151 which is for the oxygen sensor circuit heat switch. I've read online and had a few mechanic friends tell me that is almost always a vacuum leak. In the process of flipping the car I've added some aftermarket parts to appeal to the new buyer but the check engine light came on before I started swapping parts over (mufflers, throttle body and intake, rear oxygen sensors) and I have replaced all the major hoses like coolant hoses and vacuum hoses around the intake. The only place I can find that would have any vacuum leak is the hose that goes to the EVAP purge sensor and it goes down into the passenger side fender. I have no clue how to get to this hose aside from taking the whole fender off lol. Has anybody worked on these rubber hoses or know what I can do to ditch this code?
Old 10-01-2015, 03:27 PM   #2
Originally Posted by zlwhat View Post
i buy and flip cars all the time and i am used to them having check engine lights and little issues but prepare myself to fix them before selling them on. But i bought this 1998 gt and it didn't pop a check engine light until after i had driven it for almost a week. It's a p1151 which is for the oxygen sensor circuit heat switch. I've read online and had a few mechanic friends tell me that is almost always a vacuum leak. In the process of flipping the car i've added some aftermarket parts to appeal to the new buyer but the check engine light came on before i started swapping parts over (mufflers, throttle body and intake, rear oxygen sensors) and i have replaced all the major hoses like coolant hoses and vacuum hoses around the intake. The only place i can find that would have any vacuum leak is the hose that goes to the evap purge sensor and it goes down into the passenger side fender. I have no clue how to get to this hose aside from taking the whole fender off lol. Has anybody worked on these rubber hoses or know what i can do to ditch this code?
Sent from my iphone using mustang evolution
Possible causes
- Faulty Oxygen Sensor
ALWAYS START WITH FIRST LISTED CAUSE,BREAK OUT YOUR DVOM AND CHECK VOLTAGE OUTPUT FROM OXYGEN SENSOR. GOOGLE THE CODE IF YOU DON'T HAVE MANUAL,NET WILL LEAD YOU THROUGH TEST. JUST ENTER CODE AND OBD2
ALLYDRIVER1 is offline   Reply With Quote
Old 10-01-2015, 04:06 PM   #3
Originally Posted by ALLYDRIVER1 View Post
Possible causes
If it was an oxygen sensor I'd be getting the p1051 code which is oxygen sensor fault. Usually the p1151 will Pop when the p1051 does
Old 10-01-2015, 09:46 PM   #4
Google code just trying to help you should always check first code first.the kast thing on list of 6 things to check is vacuum leak. In 40 something years of working on fords have never seen a vacuum leak cause a code 1151 only worked on the pcm's from 86 till retired in 2001
Old 10-01-2015, 10:34 PM   #5
Yeah I hear you and don't think I'm not appreciative of that as well. I've only got about ten years under my belt but not necessarily on fords the whole time. But people love mustangs and they are easy to fix. Luckily I got this one cheap and despite the check engine light it still runs nice and strong with 98k miles on it.
Old 10-02-2015, 11:33 AM   #6
check those ft o2 sensors
Old 10-02-2015, 12:17 PM   #7
ch0wd0g's Avatar
I know it sounds crazy, but have you changed the plugs? I have got that code a couple of times on my 98 GT and it was always the spark plugs. Once I change the plugs, the code doesn't come back until the next time it needs it.
I know it sounds silly, so I have my suit on now.
1998 GT that rebuilt from salvage.
2015 GT 50th Anniversary Edition.
ch0wd0g is offline   Reply With Quote
Old 10-02-2015, 04:43 PM   #8
P115151CODE
Remove the front passenger side tire and the cover inside the fender. That's where your part is located. It's part of your evaporative system. I had the same problem.
tonyjuan is offline   Reply With Quote
Old 10-03-2015, 12:04 AM   #9
That's exactly the response I've been looking for! One of the probable causes for the code is leaks in EVAP system. That's why I assumed that nasty torn up hose going into the fender well was the cause.
Old 10-03-2015, 12:06 AM   #10
I replaced the plugs with brand new motocraft factory plugs and got the blue ford racing wires as well. Still has stock coils but runs really well. I'm averaging about 18-19 mpg on the highway with 3:73 rear gears.
P1055 code help.. Need inspection Bad cory21 2005-2010 Mustang GT 10 06-24-2012 08:06 PM
P1151 Blackedout Pre-2005 V6 Mustang 28 06-22-2011 07:55 PM
2002 V.6 codes p0175 p1150 or p1151 LittleSue Pre-2005 V6 Mustang 1 05-12-2011 10:34 AM
FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? kele74 Classic Mustangs 4 03-16-2010 05:12 PM
Need Help: Car throwing EEC-IV Code 224 PureVenom General Mustang Discussion 3 01-04-2009 05:27 PM
04:02 PM
