So Long, Old Engine: Bad Head Gasket - Mustang Evolution
Old 10-03-2015, 09:09 PM   #1
TheJigShow's Avatar
So after plenty of trial & error along with process of elimination, I finally determined the cause of my engine troubles: a bad head gasket. I'm not all too surprised on an engine with 170K miles, but nevertheless, I've decided to just replace the engine, instead of tearing down the old one to replace the head gasket.
Anyone know where I can find a good used 4.6 2V for a good price? Preferably one between 40K-60K+ miles; I'm just looking for something that will be reliable will just get me going again.
"Jig"
2014 Ford Focus ST (ST3, Tuxedo Black Metallic)
1997 Ford Mustang GT (Rio Red) (RMR #7832)
2003 Ford Mustang GT Centennial Edition (Black) (SOLD)
2004 Ford Mustang GT (Redfire) (SOLD)
1985 Chevrolet C10 Custom Deluxe (Red) (SOLD)
TheJigShow is offline   Reply With Quote
Old 10-03-2015, 09:56 PM   #2
Steve96's Avatar
Search your local pick and pulls im sure you can find an 04 + PI motor without too much trouble. Just google it and you will find plenty of options, look for one closer to cut down on shipping.
1996 GT
Old 10-03-2015, 10:36 PM   #3
I bought a motor out of a 2005 grand marquis and it only had 48k miles on it complete from intake to oil pan for $550 at a local pick and pull. Threw it in a old f150 and now the motor has about 100k on it and running great.
Old 10-03-2015, 10:54 PM   #4
TheJigShow's Avatar
I'm guessing engine-wise, it's the same PI engine found in a late 2001-2004 GT? If so, what other cars had the same engines?
"Jig"
Old 10-04-2015, 01:01 AM   #5
Yes it was the exact same. All I had to do was run coils and wires from my stock set up rather than COPs so that way I didn't have to modify any harnesses
Old 10-04-2015, 04:35 AM   #6
TheJigShow's Avatar
Well that's convenient lol. I probably would rather find a crown Vic engine anyways, considering it wouldn't have been beaten on, not like a Mustang engine lol
"Jig"
Old 10-04-2015, 07:18 AM   #7
Panther140's Avatar
www.car-part.com That's where I got my 70k mile Crown vic engine. If you have a car newer than 1999, it will be easier to find the correct PI engine for your car. The 99s were made in the Windsor plant instead of the romeo plant. The main hurdle with that is the 8 bolt mains instead of 6 bolt mains. You would need a new flywheel to run a romeo engine in a Windsor-equipped car, and vice versa.
Panther140 is offline   Reply With Quote
Old 10-04-2015, 12:38 PM   #8
fenixignition's Avatar
99 to mid 01 are the windsors i believe.
2002 GT 5sp. 16x,xxx miles
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 10:51 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 02:24 AM
leaking head gasket tedness Pre-2005 V6 Mustang 5 03-07-2005 10:06 PM
leaking head gasket...what? tedness The Bar 1 03-07-2005 09:43 PM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
10:00 PM
