Stock CAI to 75mm TB - Mustang Evolution
Old 10-04-2015, 01:56 PM   #1
fomoco4life's Avatar
I want to keep my stock air intake for now but I have a 75 millimeter throttle body and can't get the tube over it is there some type of sleeve that steps up. I think most aftermarket CAI have one but I can't seem to find one by itself
Old 10-04-2015, 02:01 PM   #2
If you go to autozone and go into the intake section you can buy a coupler that should make it fit.
Sent from my LG-H634 using Mustang Evolution mobile app
19robby2 is offline   Reply With Quote
Old 10-04-2015, 02:02 PM   #3
This is an example.
Old 10-04-2015, 04:47 PM   #4
fenixignition's Avatar
but the stock tube is rubber.
you may need an aftermarket metal tube, and then use that adapter to attach it to the stock mafs.
2002 GT 5sp. 16x,xxx miles
Old 10-04-2015, 10:20 PM   #5
Originally Posted by 19robby2 View Post
This is an example.
Yup, this might work, I'll check thanks
Old 10-06-2015, 08:22 AM   #6
Just leave your stock TB on then, especially if your plenum is still stock. I'd say upgrade the plenum, TB and go to a JLT air intake at that point in time. Its the only CAI I would recommend TBTH.
Old 10-06-2015, 09:13 AM   #7
This is the new plan for now, I have a C&L plenum, but I'm going to wait till I can afford a tuner to get the CAI. Just cleaned my stock TB and plenum, man they were caked up. Are JLT's CARB compliant for California?
Old 10-07-2015, 09:04 AM   #8
No idea if they are, check the JLT website.
Old 10-09-2015, 07:36 PM   #9
Speed_Mister's Avatar
Region: Arkansas
Get a heat gun and heat the tube up a bit and some wd46 it will slip right on it. I have 75mm throttle with stock intake.
2004 Mustang GT 5 Speed Full Bolt Ons 385rwhp 450rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 10-09-2015, 09:54 PM   #10
Excellent info, thanks
cai
MAC 75mm Throttle Body Thomas91169 Mustang Parts for Sale and Wanted 1 11-09-2005 08:29 AM
75mm Plenum/Throttle Body installed Thomas91169 1996-2004 Mustang GT 20 10-18-2005 06:28 PM
65mm TB w/kit, 42s, 75mm Pro-M pete Mustang Parts for Sale and Wanted 0 10-08-2004 08:28 AM
75mm Pro-M MAF OrangeV6F150 Mustang Parts for Sale and Wanted 1 09-20-2004 08:27 AM
06:15 PM
