Rear end squealing - Mustang Evolution
Old 10-06-2015, 10:37 AM   #1
robin_gt's Avatar
Rear end squealing
Hey so ive had a squealing issue with my rear end for quite a bit now, it has gotten really loud and annoying/embarrassing. Before a little road trip i cleaned the crap out of my rims and today i noticed that the rear drivers side wheel is WAY more dirtier than all the other wheels, looks like brownish filth dust( i think its brake dust). Could brakes be causing squealing that sounds like a bearing? What are some other components that could be causing squealing in the rear end? Im gonna put the rear and on jack stands later today and let the wheels spin to kinda break down where the squealing could be coming from. Thanks
robin_gt is offline   Reply With Quote
Old 10-06-2015, 11:14 AM   #2
It could be that the caliper is sticking on that wheel.
Old 10-06-2015, 12:31 PM   #3
Steve96's Avatar
Sounds like a sticking caliper to me. My car did this over the summer for one night then hasnt done it again. But when it did the brake dust was very much more noticeable on that rear wheel.
1996 GT
Old 10-06-2015, 12:33 PM   #4
robin_gt's Avatar
i will take a look at the rear brake calipers this weekend and maybe grease the sliding pins to see if that helps
Old 10-06-2015, 04:22 PM   #5
escottcarp's Avatar
Does the rim get hot during the drive? That's a sure sign of a sticking caliper. Stuck slide pins are typical causes of sticking calipers.
It's an easy fix. Just install and lube new slide pins.
escottcarp is offline   Reply With Quote
Old 10-11-2015, 09:50 AM   #6
robin_gt's Avatar
UPDATE
ok so i just put the rear end on jack stands and put the car in 3rd gear to spin the wheels, noticed a slight wobble in the rim, took the wheels of and it seems like both sides are not spinning straight
Brakes are kind of dragging on drivers side which explains the amount of brake dust thats on the rim, passenger side squealing, sounds also like the brakes, so next weekend im going to get the rotors cut and putting new pads in. Now that brace on the pumpkin where you jack up the car (i am going to tighten the 2 bolts today while the car is up in the air, whats the torque spec for those 2 bolts?) is also loose, is that a reason for the axles not to spin straight? i attached 2 links to a video of the whole situation.
Please help
Old 10-11-2015, 10:47 AM   #7
robin_gt's Avatar
Just took off the brakes and both axles are wobbling inside out. What could be the causes of this? And also the squealing is coming from the passenger brakes. Will replace pads. Can these rotors still be cut or do i need new ones? Click image for larger version
Name:	ImageUploadedByMustang Evolution1444582023.204361.jpg
So do i need new axles? Kinda weird that both side wobble at the same time.
Old 10-11-2015, 12:24 PM   #8
robin_gt's Avatar
One more with the wheels on
Any ideas?
Old 10-11-2015, 01:12 PM   #9
Either those axle shafts are bent or there is something loose on those rear hubs. Can't imagine it being both at the same time though. Been doing hard launches and clutch drops??
Old 10-11-2015, 01:17 PM   #10
robin_gt's Avatar
Not really no hard launches, and if i do punch it i cant get traction anyways because of these ****ty sumitomo 315 tires, worst tire by far.
Now i did have 4.10 gears installed like 7 months ago and the mechanic also replaced the axles because the bearings on the old ones were so bad they apparently damaged the old axles..
Old 10-11-2015, 01:21 PM   #11
It would be easier to tell if you would have held the camera steady, but it sure as hell looks like both of the axles are bent.
Old 10-11-2015, 01:23 PM   #12
I would take it back to him and see what he thinks about it.
Old 10-11-2015, 01:28 PM   #13
robin_gt's Avatar
Just found the receipt of the 4.10 install and the axles are still under warranty because it was shop supplied, idk what kind of ****ty axles they used but i will give them a call tomorrow and see what they have to say to the whole situation. So are you pretty positive on the bent axles? is it unusual that both bent at the same time?
Old 10-11-2015, 01:39 PM   #14
I would think that it is VERY unusual. But since both were replaced at the same time, perhaps it is a manufacturing defect?
From what I saw on the video, it definitely looks like there is noticeable run out on the axle flanges. You can see it with the naked eye.
Show the mechanic the video.
Old 10-11-2015, 01:44 PM   #15
robin_gt's Avatar
will do. Could there be any other causes other then bent axle shafts that could cause the wobbling? Is it safe to drive like this right now?
Old 10-11-2015, 01:58 PM   #16
I don't know of anything else that would cause that.
If it still drives and stops alright, then I think that it is safe to drive. You have to be the final judge on that matter though.
And which bolts are you referring to, that need tightening?
Old 10-11-2015, 02:02 PM   #17
robin_gt's Avatar
The 2 bolts that hold the dogbone in place right under the rear diff pumpkin.
Old 10-11-2015, 02:13 PM   #18
I don't see a a torque spec for that so I would just make it good and tight.
Maybe 60-70 ft-lbs.
Old 10-11-2015, 02:30 PM   #19
robin_gt's Avatar
Maybe 60-70 ft-lbs.
Ok thanks for all the help i´ll report back tmrw with what the mechanic said. thanks!
Old 10-12-2015, 11:51 PM   #20
Steve96's Avatar
Just took off the brakes and both axles are wobbling inside out. What could be the causes of this? And also the squealing is coming from the passenger brakes. Will replace pads. Can these rotors still be cut or do i need new ones? Attachment 192177
I would just get new rotors, i know their more expensive but you will have piece of mind. I would say yours are border line of being ok to be turned. Take them to a auto parts store that does that and have them inspect them. I always have just put new rotors on my cars when doing the brakes and it always has worked out very well for me.
1996 GT
Old 10-15-2015, 11:37 AM   #21
robin_gt's Avatar
Update
So i took the axles out and gave them to the mechanic i got them from, he returned them and got new ones. Last night i put the new ones in and now both wheels are spinning completely straight. Guess i bent both axles lol. Thanks for all the help and advice.
Old 10-15-2015, 09:37 PM   #22
Steve96's Avatar
Just toooooo much torque, huh?!! Jk
1996 GT
Old 10-15-2015, 11:05 PM   #23
one more with the wheels on
any ideas?
when you put those spacers on did you remove that thin clip that holds the rotor on? Fixed one last week by removing those clips. They are there to hold rotors on while going down the assembly line only.
As for your rear-end squeal stay away from spicy food and beans for a few days
ALLYDRIVER1 is offline   Reply With Quote
Old 10-15-2015, 11:10 PM   #24
never mind just saw your axle post
Old 10-16-2015, 10:34 AM   #25
escottcarp's Avatar
Did you change the rear wheel bearings, too?
I imagine the bearings could be damaged with bent axle shafts.
Old 10-16-2015, 05:11 PM   #26
jeno's Avatar
Love this⬆️
Sent from my 2003 rocketstang using Mustang Evolution
jeno is offline   Reply With Quote
Need with squealing in the rear end of car BeastGT 2011-2014 Mustang GT 3 09-03-2014 08:36 PM
Metal squealing noise after driving for a while Patches89 1979-1995 Mustang GT 11 08-20-2012 06:09 PM
squealing noise 98mustang11 Pre-2005 V6 Mustang 14 04-17-2012 04:21 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
06:07 PM
