Need some advice. - Mustang Evolution
Old 10-09-2015, 09:21 AM   #1
WrenchTurner18's Avatar
Region: Arkansas
Exclamation Need some advice.
This upcoming Monday, I'm picking up a 97' Mustang GT 5 Speed. It has the 4.6. It has, cold air intake, & two MSD coil packs. The cars been sitting a while but still runs and drives great. Drove it the other day. But I did notice, that the car is starting to smoke on startup, and if idled for very long, it will smoke. As soon as I get it, I'm changing the spark plugs, oil, & oil filter. Should I change the coil packs? Should I change the wiring gauge as well? Need some advice on what all to do to my mustang since its been sitting for a minute. Thank you.
WrenchTurner18 is offline   Reply With Quote
Old 10-09-2015, 10:14 AM   #2
retiredvet's Avatar
Run obd scan, compression test, how much gas in tank and how long has it been sitting?
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 10-09-2015, 11:51 AM   #3
Region: Arkansas
I have an obd scanner. I don't have anything to test the compression. It's hasn't really been sitting. He drives it like once a week maybe?
Old 10-12-2015, 01:54 AM   #4
Junior Member
Get a detailed checkup.. Run it on an engine cleaner full tank.
Sent from my D6633 using Tapatalk
alamri.ahmed is offline   Reply With Quote
Old 10-12-2015, 05:00 AM   #5
bucko's Avatar
The smoke you are seeing on first startup or long periods of idle are most likely the valve guides, or valve guide seals. A compression test will verify this as to rings or seals.
96 3.8l with some bolt ons whats next...? Need some advice please!!! Mavs32 Pre-2005 V6 Mustang 6 02-02-2011 04:56 PM
Need Some Advice Herbstang Pre-2005 V6 Mustang 9 01-24-2005 03:09 PM
Need some advice on some realistic numbers from enginebasics ASSEMbler Pre-2005 V6 Mustang 25 11-14-2003 01:44 PM
Brand new here need some advice on my 95 3.8! eNvy Pre-2005 V6 Mustang 25 11-11-2003 07:35 AM
Need some engine advice B4 I go to the races Rellik Pre-2005 V6 Mustang 24 07-17-2003 06:16 AM
02:47 AM
