How to find out what gears i have - Mustang Evolution
Old 10-12-2015, 01:52 PM   #1
joe_117's Avatar
So it has come to my attention from my friends, that i do not have stock gears.
They think i have 3.53 or 3.73s. Well i wanna know how i can find out. If i have to take it to a shop i will but if i can do it at home please inform me.
joe_117 is offline   Reply With Quote
Old 10-12-2015, 02:19 PM   #2
Slater2111's Avatar
Jack the rear end up and turn the driveshaft. Pick a lug nut and see how many revolutions it makes for one revolution of the driveshaft.
Slater2111 is offline   Reply With Quote
Old 10-12-2015, 02:25 PM   #3
Slater's way is best, but if you don't have access to a jack and jack stands, you could try this:
Mustang Rear Gear Ratio to RPM Chart | AmericanMuscle
See how many RPMs @ 65mph and you should be able to figure out the gear. If you are going to jack your car up, please use stands or some other form of support. Going under the car and moving things with just the jack is playing with fire. Let us know what you come up with! If you do have non-stock gears that must be a pleasant surprise.
VeryVeryEvilGuy is offline   Reply With Quote
Old 10-12-2015, 02:38 PM   #4
You got it the other way around.
You see how many times the driveshaft turns per 1 wheel revolution.
Old 10-12-2015, 02:40 PM   #5
Slater2111's Avatar
Yea that's what I meant. It would have gotten him there. Lol. Just would have had to come back and ask why it was only 1/3 of a turn. Lol
Old 10-12-2015, 06:28 PM   #6
joe_117's Avatar
I have a tuner. And at 70 mph the rpms are 1850-1900.
Old 10-12-2015, 06:34 PM   #7
joe_117's Avatar
Everyone who i am friends with who have cars, or who owned 2 valves say that my car is the best running 2 valve they cam across. Besides speed mister who lives near us.
They say i do not have stock gear but i do. I really think i do.
Old 10-12-2015, 10:38 PM   #8
XSlashDashX's Avatar
You should have 3.27 if your rpms are under 2k at 70 mph.
Old 10-12-2015, 11:21 PM   #9
joe_117's Avatar
They are. But everyone says there not stock, i swear..
Old 10-12-2015, 11:31 PM   #10
Steve96's Avatar
I would say stock with those rpms at 70 mph. Mines a 96 and with 410s in a manual in 5th at 70 Im around 2300-2400 rpms
1996 GT
Old 10-13-2015, 06:07 AM   #11
It's awesome that you enjoy your car's speed with the stock gear set. Any other mods your car might have that might contribute to fast feeling? Maybe the tune you're running? I know stock vs tune makes a pretty big difference in feel, even with a mild street tune.
Old 10-13-2015, 06:08 AM   #12
fenixignition's Avatar
what year is your car? the transmission gears are different in certain years. a mid 01 to 04 has a tr3650 which is 3.27 stock and will run 18k rpms at 70mph roughly.
if your friends have similar mustangs, and yours is the best running one, then their's must be busted or something. are they driving yours or are they sitting in the passenger seat? because sitting in the passenger seat, a car always feels faster. maybe yours is louder so they think your rpms are higher when not looking at the gauges?
2002 GT 5sp. 16x,xxx miles
Old 10-13-2015, 06:09 AM   #13
Also tire size, specifically tire height, will have an impact like gears. Shorter tires will have similar effect on acceleration as shorter gears. Are your stock or aftermarket?
Old 10-13-2015, 10:20 AM   #14
retiredvet's Avatar
Also some cars, for whatever reason, run like a scalded dog from the factory.
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 10-13-2015, 12:28 PM   #15
joe_117's Avatar
My mods are a bassani off road x pipe, with slp catback
X4 tune by mpt running 93 performance
Mgw short throw
---------- Post added at 06:28 PM ---------- Previous post was at 06:27 PM ----------
Late 01, yes i have 3650.
Old 10-13-2015, 12:30 PM   #16
joe_117's Avatar
I have aftermarket tires.
Fronts 245/45 17s
Rear 285/40 17s
Old 10-13-2015, 12:31 PM   #17
joe_117's Avatar
I also let them drive it. And they act like they never came across a 2v. They say something is done
Old 10-13-2015, 12:39 PM   #18
A lighter and less restrictive exhaust system like yours coupled with a Race Tune will definitely get a noticeable jump off the line. 285/40/17 tires have just under 26 inch height, if I'm not mistaken. If your friends have tires that are taller, then that accounts for your difference in acceleration. Sorry, don't know the stock tire heights for the earlier 2000's GTs.
Old 10-14-2015, 01:35 AM   #19
joe_117's Avatar
Ohh yea, my exhaust set up is top end. Gained power at higher rpms, but lowest slight low end
Old 10-14-2015, 05:18 AM   #20
245/45/17 for new edge gts. 3.8's have a close wheel base, but slimmer, longer tire and smaller rim.
but either way, theres a lot to factor here. were talking about butt dyno.
mine doesnt launch very well, and by that i mean simply taking off in normal traffic. but in reverse, i can practically drag race backward. Im assuming its because of my worn rear suspension.
Old 10-14-2015, 05:50 AM   #21
Good point about butt dyno. Sometimes a car just feels faster. Your wide tires are definitely going to give some good traction, which might make the car feel more responsive and quick. Have you tried timing your launch to see how fast it actually is say 0-60 or 1/4 mile vs your friends? I really think that the traction from the wider wheels, lighter exhaust, and the race tune are what's giving you such a power boost, or at least feel, over what your friends drive. An aggressive tune alone will do wonders to a car, especially a GT. Now, imagine if you changed up your gears on top of all that jaja
Old 10-14-2015, 07:28 AM   #22
Drop some 4.10s 👍
I have a 2005 GT with V-3 supercharger and borla exhaust. Looking to find out what ex 1BAPONI Mustang DIY and Technical 0 07-30-2014 05:31 AM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Need quick help! Need to find 4.10 gears for 2010 v6 mustang?? Camaro Eater Pre-2005 V6 Mustang 2 06-08-2010 05:31 AM
These guy's have all the hard to find parts PureVenom The Bar 5 09-23-2007 02:32 PM
06:30 AM
