Next power mod - Mustang Evolution
Old 10-13-2015, 08:40 PM   #1
Next power mod
I have headers full exhaust, tb and plenum , cold air intake, and tune what should I do next besides suspension I will do next spring
04sonic is offline   Reply With Quote
Old 10-13-2015, 08:47 PM   #2
natestang07's Avatar
Cams?
Old 10-13-2015, 08:48 PM   #3
I was thinking that drop about 1500 2000 though
Old 10-13-2015, 08:58 PM   #4
That sound though..
Old 10-13-2015, 09:02 PM   #5
I agree it is amazing
---------- Post added at 03:02 AM ---------- Previous post was at 03:01 AM ----------
Would plugs and coil packs be worth it? Also was looking at upgrading to the bbk fuel rails
Old 10-13-2015, 09:03 PM   #6
keeney35's Avatar
Do you have gears?
keeney35 is offline   Reply With Quote
Old 10-13-2015, 09:04 PM   #7
I do not have gears I have an auto 4.10s the best?
Old 10-13-2015, 09:12 PM   #8
Steve96's Avatar
Go gears next. 410s, and J mod. Then your suspension and you will be sitting pretty. Full bolt ons, tune, j mod, 410s, suspension on a good day could probably get you into the 12s or so in the 1/4
1996 GT
Old 10-13-2015, 09:22 PM   #9
410s shift at a higher rpm right?
Old 10-13-2015, 09:29 PM   #10
keeney35's Avatar
No it doesn't change shift points just accelerates faster.. But don't do cams just yet.. That should be the last thing you do bolt on wise..
Just FYI cams aren't 1500-2000. Buy the cams, adjustable crank gears, upgraded valve springs, timing set and gaskets and your at like 1000.. And honestly if you pretty good with cars the install isn't bad
Old 10-13-2015, 09:56 PM   #11
retiredvet's Avatar
Just look at my signature for my mods and my times. I have ported heads which most don't bother with but if u do cams wait and do heads as well. For you.. 2400 stall, jmod, 4.10's, and go ahead and replace those shocks and struts with some koni's now. You will be right at budget and in the high 12's
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 10-14-2015, 05:40 AM   #12
I can't go to low my cats on my x pipe hang a little bit. Is there a way to pull then x up?
Old 10-14-2015, 08:14 AM   #13
keeney35's Avatar
Just drop it an 1.5" on steeda springs.. But save up so you can do the springs, steeda x2 ball joints, shocks and struts and mm caster camber plates at the same time
Old 10-14-2015, 08:47 AM   #14
Sterlingbeast5.0's Avatar
Control Arms, Gears, Torque converter. Keep in mind torque converter is based on what I have read here. I have a manual
Old 10-14-2015, 03:56 PM   #15
X pipe only clears the ground by about 1.5-2 inches
Old 10-14-2015, 06:11 PM   #16
keeney35's Avatar
My H clears by couple inches and I'm lowered and 1.5",
Old 10-14-2015, 06:12 PM   #17
My suspension is all stock now if I lower that won't it be to close to the ground
Old 10-14-2015, 08:35 PM   #18
Steve96's Avatar
Sounds like its hanging a little low to me. The UPR off road X sits fairly tight from what i have read or go H pipe. I have a BBK X pipe and im on H&R supersports which are a little under 2" lower than stock and im fine unless i go into a steep driveway or a large speed bump. Just be careful and go in on an angle.
1996 GT
Old 10-14-2015, 08:37 PM   #19
Is there anyway to pull it up some? Maybe cut a little off at the top and pull it uo a bit?
Old 10-14-2015, 10:16 PM   #20
keeney35's Avatar
A little of the top? Just have an exhaust shop cut it and reposition it
Next "worthwhile" power mod? Jvibe92 2011-2014 Mustang GT 6 04-14-2015 03:03 PM
Truck will be forsale next spring. What to get next? sonic04edge The Bar 28 09-26-2006 07:45 PM
Next mod? blownsix The Bar 9 07-25-2004 06:13 PM
What should my next Mod be? tippie2000 Pre-2005 V6 Mustang 24 04-07-2004 03:49 PM
next mod: Rellik The Bar 11 10-18-2003 08:03 AM
06:01 PM
