Thoughts on 1" spacers - Mustang Evolution
Old 10-14-2015, 12:22 PM   #1
fomoco4life's Avatar
Opinions, I'm kinda in the air on the looks with these, what do u guys think ? They're the MM 1" hubcentrics, on 275/40/17
ID:	192306   Click image for larger version
Old 10-14-2015, 12:26 PM   #2
What are you in the air about? I have a set and I think they look good. With stock rims I think I would've went with a 1.5, but I'm getting new rims soon so I think 1 is good.
wawanesa5speed is offline   Reply With Quote
Old 10-14-2015, 03:19 PM   #3
Lorraine's driver
ab_mach1's Avatar
I think they look good. Only reason why I don't have them is because I worry them breaking lol. 1.5" would be too much IMO.
Instagram: @ab_mach1
Old 10-14-2015, 03:56 PM   #4
Haha well I'll let you know if mine snap!
Old 10-14-2015, 04:54 PM   #5
That is one of the things I'm in the air about lol ...how long you been running yours
Old 10-15-2015, 10:43 AM   #6
I've been using mine with the stock gt wheels for around 7 months. Just the rears, car has full bolt ons and is dailyed.
Old 10-15-2015, 11:00 AM   #7
You will probably be fine on the rear wheels as long as you installed them properly and checked the torque after about a couple hundred miles.
I don't suggest ever using spacers on the front wheels because they are the ones that always seem have problems.
Old 10-15-2015, 11:11 AM   #8
Lorraine's driver
ab_mach1's Avatar
I agree ^ Seems like most failures are because of using the cheapo ones or improperly installed.
As for me, I'm just too chicken to run them. It isn't that important to me to have the wheels out to the fender in the back enough to pay for them anyways.
Old 10-15-2015, 11:25 AM   #9
Yeah exactly. I just hated that horrible tuck in the back, also my rims/tires are being replaced soon so I thought I'd give them a try. No regrets so far!
Old 10-15-2015, 03:15 PM   #10
Yep, I think I'll keep em til I go deep dish. Way more agressive look, and I don't feel any vibration issues,etc. plan on checking torque often. I think I'm just about done spending $$ on this car.... Yeah right
Old 10-15-2015, 04:05 PM   #11
I'd only run spacers with upgraded wheel studs.
Old 10-15-2015, 09:36 PM   #12
Steve96's Avatar
I think those look good. I dont like them with a 10 or 10.5" wheel though, they stick out a little too far IMO. You are getting the visual effect of a 10" wheel with those.
1996 GT
Old 10-16-2015, 07:50 AM   #13
joe_117's Avatar
I have a question, didnt wanna make a new thread.
I have 17s, if i go 18s will it slow me down or anything at all?
joe_117 is offline   Reply With Quote
Old 10-16-2015, 11:30 AM   #14
No , I believe 18's are preferred (eliminates wheel gap, and just plain looks better) I'll be going 18x9 and 18/10.5 eventually. Plus you actually gain a little ground clearance with the 18's.
I will say this ...the guys with the 20 inch rims on their Mustang... make me want to hurl ... Meh, basically every car I see with 20's makes me want to hurl lol
Old 10-16-2015, 11:46 AM   #15
parkerz28's Avatar
18" rims don't necessarily change wheel gap... The tire size does. For example I have 285/35/18 in the rear and they are almost the same outside diameter of my stock 17" rims and tires. This way there isn't a need to recalibrate the speedo
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 10-16-2015, 12:22 PM   #16
Very true... tire size plays a huge role, I should have stated that
Old 10-16-2015, 01:09 PM   #17
joe_117's Avatar
I was told 18s will make me go slower. Im thinking about going 18s, but if it will slow me down, il pass
Old 10-17-2015, 07:54 PM   #18
skyline247's Avatar
It's the overall tire height that matters, not necessarily wheel diameter. If you get a tire for the 18" wheel that gives you the same overall tire height as what you have on the 17" wheel, then it shouldn't affect you. Keep in mind that if the tire height is different, you need to recalibrate the speedo.
Sent from my Nexus 6 using Tapatalk
1988 GT - Stock
*SOLD* 2012 GT Premium, Black on Black, 3.55 Axle, HID and Security Package, Pypes Pype Bomb Axle Backs
skyline247 is offline   Reply With Quote
Old 10-17-2015, 10:02 PM   #19
retiredvet's Avatar
I would seriously rethink taking advice from whoever told you 18's will make you go slower. Their ignorance should be criminal.
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 10-17-2015, 10:26 PM   #20
Speed_Mister's Avatar
Region: Arkansas
Maybe slower from a dig race because of less sidewall. And really the taller diameter of tire the more longer gearing you have, so if you have 4.10 gears on a 25 inch tall tire you're gonna max out 2nd gear at 50 mph on redline. 26 inch tall with 4.10s you will redline 2nd at 55ish and so on..
2004 Mustang GT 5 Speed Full Bolt Ons 385rwhp 450rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 10-17-2015, 10:32 PM   #21
Although a taller wheel and tire package lowers the number for your rear gear ratio as stated above...............if the tires and wheels you are going to are significantly heavier -- they will indeed slow you down a LOT.
It's called rotational resistance or inertia. It simply takes more horsepower and torque to get them rolling and to keep them turning. Takes more brakes to stop them too, so may lengthen your stopping distance. Wheels and tires that are a lot heavier will affect your handling as well as your shocks need to recover all that new weight after each bump.
Just pay attention to the overall weight and height of any tire/wheel package you are thinking of buying. You will feel a big difference even if you only go up 5 or 6 pounds a corner.
Old 10-18-2015, 12:45 AM   #22
joe_117's Avatar
You do 17s for a DD don't you?
Old 10-18-2015, 07:07 AM   #23
Hey Guard 5.0
Excellent
Old 10-18-2015, 09:50 AM   #24
Region: Arkansas
I'm on 15 drag pack. Selling my 17's.
Full Bolt Ons
370rwhp 470rwtq
Old 10-18-2015, 09:57 AM   #25
Region: Arkansas
17x10.5 with nto5r 315 radials and 17x8 235 tire up fronts $650. Just saying...
Full Bolt Ons
370rwhp 470rwtq
Old 10-18-2015, 02:09 PM   #26
What rims are they?
Old 10-18-2015, 04:42 PM   #27
Region: Arkansas
Originally Posted by fomoco4life View Post
What rims are they?
Name:	ImageUploadedByMustang Evolution1445208075.019578.jpg
These rims bought thru American muscle 8 months ago. No scratches on them. Need new rear tires had them listed for like $850 but lowest I'll go is $650 plus shipping.
Full Bolt Ons
370rwhp 470rwtq
MTI RACING "Extreme Velocity" 454 "Southern Stingray" C6/Z = Awesome JROC Pictures and Videos 10 10-26-2007 03:33 AM
w0000ttt!!!!! got something today (starts with "s" ends with "upercharger") fast64 Pictures and Videos 37 02-22-2005 05:52 PM
"Damn cops" and "Damn women drivers" fast64 The Bar 10 11-27-2003 07:18 PM
09:45 PM
