Provide legitimate answers - Mustang Evolution
Old 10-15-2015, 02:02 AM   #1
joe_117's Avatar
So I've done research but ended up just giving up. So i wanted to see from you guys with experience what gains i have made with these mods.
My car is the lat 01 5 speed.
Mods
X4 tune running 93 mpt tune
Off road bassani x
Slps
Mgw, which has no effect.
Can anyone give me a reasonable answer for the amount of gains i have made?
joe_117 is offline   Reply With Quote
Old 10-15-2015, 05:43 AM   #2
Strange Mud's Avatar
not a legit answer but realistic.
You have brought your 15 yo car back up to it's original HP
Old 10-15-2015, 06:12 AM   #3
fenixignition's Avatar
usually what ive seen when people post dyno results is going from 221 stock to 260 at the wheels with full bolt ons. the tune wont really do much as far as increasing horsepower, but it changes the way it drives so that its more aggressive, and probably accelerate faster. The only thing ive noticed from a more open exhaust is easier passing power on the highway.
bottom line, these engines wont go much faster with boltons or cheap upgrades (cheap being a relative term) you gotta boost if you want to keep up with newer cars.
2002 GT 5sp. 16x,xxx miles
Old 10-15-2015, 06:50 AM   #4
You are likely at 240-250 to the wheels. Not drastic gains.
There is not very much you can do power wise with bolt ons to the PI motor. 255-260 is max realistic without doing cams and then you are at 285-300 depending on the cams.
You will need a power adder or swap to a different motor to get more out of it.
That being said, a 260whp 2V with suspension and sticky tires can do high 12s with a really good driver. This is where too many ppl cheap out or completely neglect. I don't see any suspension work in the OP's list of stuff, this is very very bad. That or gears. Gears will be the biggest SOTP gain for the $$$ there is on this car.
Lower control arms, leave the stock uppers, lower the car with a good set of springs/shocks/struts/CC plates, do full length subframes and a good set of wheels and tires and the overall performance aspect of the car will drastically increase.
Old 10-15-2015, 09:50 AM   #5
It is impossible for us to give you a legitimate answer. Every car is different. If you really want to know, go schedule a dyno appointment and find out.
Old 10-15-2015, 10:10 AM   #6
alecas447's Avatar
Not really, boost isn't really needed to keep up with newer mustangs. Excluding 5.0
alecas447 is offline   Reply With Quote
Old 10-15-2015, 10:13 AM   #7
That's what we mean when we say newer, the Coyote
Old 10-15-2015, 10:15 AM   #8
alecas447's Avatar
Eco boost, v6 etc, is a drivers race, you really can't compare a coyote to a 2v, that's ridiculous
Old 10-15-2015, 10:15 AM   #9
Site Sponsor
Mods
Off road bassani x
Slps
Absolutely not. There's no way to speculate what the cars making and if you're looking for a legitimate answer you're going to need to get the car on a dyno.
I've seen factory freak 2v's put down 237 -245 stock to the tire where as an 02' with healthy bolt ons make 11hp less.
We need to take into consideration the age and mileage of the car because every year whether we like it or not our cars will lose power.
Where are you based out of? I'm happy to track down someone that can strap her down.
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 10-15-2015, 10:17 AM   #10
yea shoulda been clearer. but i meant like the 400hp off the lot new cars. but you can boost a 2v into a drivers race with a coyote. long as they dont boost i guess.
Old 10-15-2015, 10:19 AM   #11
alecas447's Avatar
I know but other mustangs boost is not needed
Old 10-15-2015, 10:20 AM   #12
Unless we buy mods every year, right?
Old 10-15-2015, 10:52 AM   #13
alecas447's Avatar
My car is stock and still pulls pretty good
Old 10-15-2015, 11:39 AM   #14
If the Coyote has basic bolt ons and suspension with a good driver then no. The Coyote is a freakishly good motor and the whole driveline on the S197 is damn good, especially the automatics.
Old 10-15-2015, 11:58 AM   #15
Lorraine's driver
ab_mach1's Avatar
Also, the 2011+ V6's will be tough to beat. The thing to remember about the newer Mustangs is that the power plant is so much better in making power. The V6 engine revs higher and has better power curves throughout. Most of the V6's I've seen at the track are easily under 14 sec 1/4 miles with just exhaust and a tune.
Instagram: @ab_mach1
Old 10-15-2015, 12:10 PM   #16
alecas447's Avatar
When I'm at the strip it's mainly roll racing after 100 the v6 died out
Old 10-15-2015, 12:13 PM   #17
Basically the 3.7L is on par with the 3V. If someone was to just hand me the keys to either a 2004 2V, a 2009 3V or a 2011 V6 I'd take the V6 without even having to think.
Old 10-15-2015, 12:17 PM   #18
alecas447's Avatar
I'd do the same , sell the v6 and have a good amount for a down payment on a coyote
Old 10-15-2015, 12:18 PM   #19
Lorraine's driver
ab_mach1's Avatar
Same here. I'd stick with the specials for Mustangs older than 2011.
Old 10-15-2015, 12:56 PM   #20
I'd pick the 3v.
Then throw some FRPP Hot Rod cams in it and electric cutouts. Might be slow, but will shake the earth lol
Old 10-15-2015, 01:03 PM   #21
Site Sponsor
I said no such thing! You're killing me! But we do have that shiny MustangEvolution Forums Discount Code, cough cough!
I know you guys know just as well as I do with this motor if you're looking to lay the smack down heads, cams, beefy injectors and a pump will wake these cars the hell up. There's nothing that sounds better than a 345whp 2v anyway
Alex
Old 10-15-2015, 01:08 PM   #22
joe_117's Avatar
The only thing i would do is spray. Im considering a nitrous outlet kit.
Old 10-15-2015, 01:27 PM   #23
2013_DIB_GTCS's Avatar
I've run an 02 2v running a proc harder d1 at 10 lbs putting out 380 at the tires when I had my coyote, completely stock. Got beat by .2 tenths at the track. Both were on street tires. Once I did exhaust intake and tune I was pulling on him by 3 car lengths.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
2013_DIB_GTCS is offline   Reply With Quote
Old 10-15-2015, 07:26 PM   #24
And then he does basic bolt ons and a tune and puts an easy bus length on you. And then you do a full build and run 10s and then some dude shows up with a twin turbo Coyote and runs a 9 on stock heads and cams. Always someone faster but it makes much more financial sense to get a Coyote. Only reason I have the car I have in my sig is I paid $5500 for it with 34k miles and it is a numbered car. I will have about $12k into it making 425-450 at the wheels when all is done and I still don't expect to beat a well put together bolt on and suspension Coyote at the 1/4.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 10-15-2015, 07:48 PM   #25
Put in a coyote.... Bam, best of both worlds.
Old 10-15-2015, 09:50 PM   #26
joe_117's Avatar
stop rubbing it in my face💐
Old 10-16-2015, 08:29 AM   #27
Honestly for the costs of doing everything plus bolt ons plus tuning etc... etc... There are turnkey 07-09 GT500s making upwards of 700hp going in the high $20k-low $30k range. Those may currently be the best HP bang for the buck cars out right now.
That or a real low mileage base model 2011/2012 A6 Coyote for $20k you drop $5k of mods into for low 11s all motor and 10s on the sauce.
New member looking for answers!!! Won it!!! 2005-2010 Mustang GT 28 04-19-2009 08:26 AM
Yahoo Answers wiarumas The Bar 2 08-02-2007 03:28 PM
I am looking at a system to track bugs and provide better way for feature requests. Brent ME Site Help & Announcements 1 02-24-2005 05:35 PM
need feedbacks due to inconsistent answers..C spring cutting tire Pre-2005 V6 Mustang 12 03-08-2004 02:57 PM
05:47 PM
