2000 GT help!!!!! - Mustang Evolution
Old 10-15-2015, 01:45 PM   #1
2000 GT help!!!!!
bought the car 125,xxx miles bout a month ago, been sitting some. I changed fuel filter a couple times and checked fuel pressure(40 psi) just to make sure all that was in good shape. it ran great for a couple weeks then recently i drive 40 miles one way to work and about half thru the drive it starts cutting out and gets a miss. i can let the car sit for an hour or so and its like it never happened. Ive changed the pcv hose and mass air sensor, no change. other than that im not sure where to start. All i know is carbureted engines, any help would be greatly appreciated
riddle28 is offline   Reply With Quote
Old 10-15-2015, 09:12 PM   #2
You should begin the diagnosis by scanning for any trouble codes. There may be some stored in the PCM even though the CEL is not lit.
If there are no codes present, you should do a fuel pressure test while the car is having the driveability problem, if you can replicate the conditions in which it occurs.
straybullitt is online now   Reply With Quote
Old 10-16-2015, 01:23 PM   #3
its not throwing any codes right now. but ill try the fuel pressure deal, thanks
Old 10-16-2015, 01:34 PM   #4
jjsg09's Avatar
It's more than likely a coil shorting out. Very common on these cars. If your getting 40psi on you fuel pressure it's not fuel related. Does the miss get worse when the motor is under stress like when trying to speed up or taking off hard. If so it's a spark issue which more than likely is one of the coils.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 10-16-2015, 01:43 PM   #5
It could also be an ignition problem but the coils are more likely to trigger a CEL than an intermittent fuel delivery problem, such as a weak fuel pump.
The car has 125k miles on it, so it could be either ignition or fuel.
Old 10-16-2015, 03:43 PM   #6
im kinda thinking ign too. because it can sit and then run great. im gonna change plugs this weekend and see if i can narrow it down, thanks
Old 10-16-2015, 08:25 PM   #7
Nitro's Avatar
Try to check fuel pressure when it's acting up with a scan tool and a manual pressure gauge. Mine was acting similar to your and the FRP sensor on the fuel rail was crapping out on me.
99 GT, CAI,75 mm TB,TFS upper Plenum, 24# injectors, Focus pump, O/R X pipe, Running BAMA's 93 Race Tune.
Only 1 of 173 Limited Editions..
Nitro is offline   Reply With Quote
Old 10-16-2015, 08:34 PM   #8
alright ill definitely check that out
Would a 2000 v6 maf fit a 2000 gt greenstang41 Pre-2005 V6 Mustang 5 06-30-2013 06:55 PM
2000 mustang :: 2000 Ford mustang kohli412 Member Garages 0 05-02-2013 05:26 PM
2000 V6 :: 2000 Ford Mustang hihosilver Member Garages 0 06-15-2011 12:02 PM
2000$ To mod my car... need help stangnewb99 Pre-2005 V6 Mustang 17 12-16-2006 10:29 AM
2000 V6 Auto Tranny Help petrey10 Pre-2005 V6 Mustang 1 07-08-2005 09:28 AM
01:50 AM
