Cracked supercharger - Mustang Evolution
Old 10-16-2015, 07:40 PM   #1
What do you guys think. I have a friend in a machine shop that believes he can weld in and fix the break.
I'm not sure if it's a big deal since its been like that for as long as I had the car and I've put 1500 miles on it.Click image for larger version
Name:	ImageUploadedByMustang Evolution1445046022.767018.jpg
Quadracer18 is offline   Reply With Quote
Old 10-16-2015, 09:55 PM   #2
If your friend has some experience welding aluminum, that should be an easy fix.
Old 10-17-2015, 08:33 AM   #3
kapcan2k's Avatar
Thats a procharger right? Yeah I think It can be fixed.
kapcan2k is offline   Reply With Quote
Old 10-17-2015, 08:37 AM   #4
Panther140's Avatar
Yeah you could weld that up, but be careful about how you run it from now on.
Whatever caused that crack has also weakened the aluminum surrounding it. talk to your welder about lightly reinforcing the metal surrounding the crack.
You don't want to over-strengthen one part of the case. If you do, then it will not absorb stress like the other parts will. So the stress that would normally be distributed evenly throughout will be passed on to the weaker areas, which will cause a stress-concentration and break more stuff.
Make sure your belt tension and boost levels are on the lighter end of things. You are already on thin ice!
Panther140 is offline   Reply With Quote
cracked pi manifold greg_g70 1996-2004 Mustang GT 8 12-10-2004 11:55 AM
This cracked me up! Brent The Bar 4 03-27-2004 08:43 PM
Cracked Trim Piece ericstanley Mustang Audio & Video 3 02-16-2004 04:16 AM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
My Damn Windshield is cracked!!!!!!! Danger Dude The Bar 25 11-23-2003 04:59 PM
10:36 PM
