Complete A/C delete - Mustang Evolution
Old 10-17-2015, 11:49 PM   #1
keeney35's Avatar
Complete A/C delete
What all is needed to completely delete the ac?
I know you can do the v6 pulley or just order a delete pulley, but I want to get all the crap out of the engine bay..
Keep the heater core tho so I can have heat and some bit of defrost..
But is there a full write up somewhere? I'm not even sure what all under the hood is the ac, there's too much junk under there
keeney35 is offline   Reply With Quote
Old 10-18-2015, 11:42 AM   #2
keeney35's Avatar
I think I found some install info on American muscle for the delete pulley I might just use that..
Old 10-18-2015, 02:26 PM   #3
The compressor is obviously the heaviest component. You will need to remove the dashboard to remove the evaporator, but it doesn't weigh that much. The condenser is located in front of the radiator. All of the hoses and the accumulator are pretty self explanatory, as they will be attached to all of the previously mentioned components.
Old 10-19-2015, 05:59 AM   #4
fenixignition's Avatar
the alternative to the delete pulley, is to switch an idler pulley to a grooved pulley and use the belt i believe from the 3.8. i posted it a while back somewhere on this forum. ill see if i can find the info again.
UPDATE: here is it http://www.moddedmustangs.com/forums...ac-delete.html 70.5 inch belt, and a grooved idler pulley from a v6 swapped into your tensioner. dont know if this will be any more cost effective that running a pully where your compressor was.
2002 GT 5sp. 16x,xxx miles
Power steering delete and ac delete Speed_Mister 1996-2004 Mustang GT 26 03-22-2013 02:14 PM
complete new mustang photoshops fast64 The Bar 4 10-20-2003 10:08 PM
Nitrous Install Complete!~~ Joshness The Bar 3 08-12-2003 05:05 AM
Body kit is Complete V6RoushVert Mustang Audio & Video 21 08-04-2003 10:24 PM
$200+ complete supercharger, help Stang01 Pre-2005 V6 Mustang 3 07-20-2003 04:07 PM
03:03 AM
