What should I do next? - Mustang Evolution
Old 10-20-2015, 11:56 AM   #1
I have a 2003 GT with the following:
-vortech v2 supercharger
-Kenne bell boost-a-pump
-42# injectors
-Cold air intake
-pro chamber h-pipe and mufflers
-eibach lowering springs
-4:10 gears
-bullit staggered wheels
What kind of 1/4 mile would you think I'd see? What do you recommend I do next to the car. I'm still running the stock throttle body. Should I go bigger? Will I see any HP gain at all?
Quadracer18 is offline   Reply With Quote
Old 10-20-2015, 12:58 PM   #2
Have you done any suspension work? Subframes, control arms ect. Maybe some good tires? Not all about power you need a good way to put it to the ground.
wawanesa5speed is offline   Reply With Quote
Old 10-20-2015, 01:53 PM   #3
I have decent tires and wheels with 315's in the rear. I have eibach sportlines. I have not done anything else. Subframe connectors have to be welded in, right? What do those run?
Old 10-20-2015, 02:22 PM   #4
Yeah they have to be welded. MM full braces are 150 and then the price of labour if you don't weld
Old 10-20-2015, 02:24 PM   #5
parkerz28's Avatar
I would do subframe connectors for sure... They do have bolt on ones but you want them welded and full length. Then I would do lower control arms and if your not intercooled I would go that route those are what I would start with... I'm curious how well it hooks up with the 4.10s I have the stock 3.27 and at 400 whp my car spins 1st and 2nd my suspension is stock though so a stock gt would beat me from a dig lmao. Once I move into my new house I'm redoing my suspension
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 10-20-2015, 09:06 PM   #6
smsstang's Avatar
-42# injectors
-Cold air intake
-4:10 gears
Do you mind posting a picture of the car ? And did you put the supercharger in if so how much was the cost for everything ?
smsstang is offline   Reply With Quote
Old 10-20-2015, 11:30 PM   #7
Steve96's Avatar
Get some full length subframes, LCAs, sticky tire, good dampners all around. Is it a manual or an auto? Auto then go j mod, tune obviously, and you would have a great qtr mile set up, stall converter too. If manual just the suspension mods and find your sweet spot for launching rpm wise. I assume your around the 400-425 whp range with what you have. I would think you could see high 11s, low 12s, depending on conditions, reaction time, traction, elevation, etc. I dont think that number would be off base honestly. I could be way off as i have not seen that kind of power out of mine and probably never will.
1996 GT
What should my next car should be: an '07/'08 Honda Civic or a 2010 Kia Soul? Berwick General Mustang Discussion 5 03-07-2010 05:31 PM
Truck will be forsale next spring. What to get next? sonic04edge The Bar 28 09-26-2006 07:45 PM
What should i do next to my GT. Black00GT 1996-2004 Mustang GT 16 04-28-2004 11:17 PM
What should my next Mod be? tippie2000 Pre-2005 V6 Mustang 24 04-07-2004 03:49 PM
What should I get next dapack69 Pre-2005 V6 Mustang 11 08-19-2003 08:20 AM
04:12 PM
