Rebuilding the rearend - Mustang Evolution
Old 10-20-2015, 12:38 PM   #1
keeney35's Avatar
Finally got to tearing down the rear end..
New ford racing carbon trak lok kit
New spider gears
New pinion bearings
New pinion seal
New axle bearings
New axles
New diff cover
New pinion races
Ran into a bump in the road tho.. The old clutches were so pressed and tight that I've gotta cut out the old S shaped clip to get it apart..
All in all tho I'll be glad to have the peace of mind with it..
Took a couple pics for progress and the undercar shot shows you how stock my suspension is minus the lowering springs and konis.. Cool shot of the exhaust thoClick image for larger version
Name:	ImageUploadedByMustang Evolution1445366268.111709.jpg
ID:	192589Click image for larger version
Name:	ImageUploadedByMustang Evolution1445366281.331818.jpg
keeney35 is offline   Reply With Quote
Old 10-20-2015, 01:55 PM   #2
Slater2111's Avatar
I hope you don't try to use the S clip they gave you with the carbon lok kit. If so it doesn't work. Mine was in there too. It does come out without cutting it. The one supplied is for a 31 spline and literally won't fit at all. Better hope your local auto parts store carries it. I heard a rumor that you can use one from a F150 from our years.
Slater2111 is offline   Reply With Quote
Old 10-20-2015, 02:57 PM   #3
keeney35's Avatar
How does it come out without cutting it
Old 10-20-2015, 03:23 PM   #4
parkerz28's Avatar
Requires some cursing etc... Getting it back in is the sane procedure... There are several write ups on it
Sent from Rapinators trunk
---------- Post added at 09:23 PM ---------- Previous post was at 09:23 PM ----------
Same*
parkerz28 is offline   Reply With Quote
Old 10-20-2015, 03:37 PM   #5
Slater2111's Avatar
Slip joint pliers with long handles give you lots of clamping power.
Old 10-20-2015, 09:47 PM   #6
keeney35's Avatar
I read up on some other mustang and ford forums and they say you can use the 31 spline s spring.. So is there a definite answer? I'm gonna dig into it tomorrow just mainly tore it down in class today.. The only place I found online that carries the spring is cj pony parts..
Old 10-21-2015, 03:46 AM   #7
Slater2111's Avatar
It's dimensions are bigger than the hole you took the old one out of.
Old 10-21-2015, 09:43 AM   #8
keeney35's Avatar
Well the old one got torched so i guess I'm gonna try to find a 8.8 at a junk yard and use one out of there because i can't find one anywhere..
Gotta get new crush sleeves too
Old 10-21-2015, 10:45 AM   #9
keeney35's Avatar
Name:	ImageUploadedByMustang Evolution1445445859.028574.jpg
ID:	192612 somethings missing
Name:	ImageUploadedByMustang Evolution1445445881.355831.jpg
ID:	192613Click image for larger version
Name:	ImageUploadedByMustang Evolution1445445897.846845.jpg
Name:	ImageUploadedByMustang Evolution1445445915.489149.jpg
There's the old spring
Name:	ImageUploadedByMustang Evolution1445445937.066342.jpg
So much stuff
Old 10-21-2015, 10:47 AM   #10
Don't forget to soak the new clutches for several hours before install
Sent from my XT1045 using Tapatalk
Old 10-21-2015, 10:53 AM   #11
Slater2111's Avatar
Also I think you won't be able to use the spider gears. AM still hasn't changed their website where you buy the spider gears. They are for a 31 spline as well. I can tell by the picture. The 28 spline spider gears have more of a lip on the backside of the gear. 31 spline is smoother like the ones in your picture.
Old 10-21-2015, 11:04 AM   #12
keeney35's Avatar
So I have to buy new spider gears and clutch spring? FML I might as well just change to 31 spline everything
Old 10-21-2015, 11:22 AM   #13
It's really not that expensive either...you can get a 31 spline diff complete ford unit for under $200. Probably less than you paid for the clutch set and spider gears. Just throw a new pair of axles in and you're done
Old 10-21-2015, 11:54 AM   #14
keeney35's Avatar
The spider gears on the table aren't new.. Those are the ones that came out of the car.. So my only issue now is the s clip, and it might actually be the right one
Old 10-21-2015, 12:07 PM   #15
Slater2111's Avatar
Oh ok. Glad you didn't have the same issue I did.
Old 10-21-2015, 12:39 PM   #16
keeney35's Avatar
I'm doing the install in class at the tech college I'm attending and my instructor things the s clip will work so we're going to try it..
What should I soak the clutches in?
Old 10-21-2015, 12:43 PM   #17
Diff fluid
Don't forget to add friction modifier after install. I always use Ford friction modifier. It's the good smelling part...
Old 10-21-2015, 01:29 PM   #18
Slater2111's Avatar
When I soaked mine I got a second bottle of friction modifier and soaked it in that. I don't know how you're going to get that S clip to work. It just isn't he right size.
That friction modifier is the worst lingering smell you can imagine. Don't get it in things you want to keep also. It doesn't wash out.
Fun fact. You can add a bottle of that same friction modifier to an automatic transmission if you have one.
Old 10-21-2015, 08:35 PM   #19
keeney35's Avatar
Got the clutches soaking, have a spare 8.8 at school with an s clip that will for sure fit if the other one doesn't so I should be back cutting 1.6 60's soon😏
Old 10-23-2015, 01:29 PM   #20
keeney35's Avatar
Well I went to a ford dealer and got the spring for 25$..
But when I came back the "31 spline" spring was in the rearend and it was all put back together.. So apparently the spring that comes in the kit, will in fact fit.
04 GT: CAI, 3.73, Longtubes, Full exhaust, FR500 locker diff, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
Old 10-23-2015, 01:47 PM   #21
Slater2111's Avatar
I guess they may have finally got tired of getting angry guys calling them and included the right S clip. Sorry for getting you all worked up man. But I'm glad to hear you got it all back together. Now see if you can take back that one to ford.
Old 10-23-2015, 02:10 PM   #22
keeney35's Avatar
I'm gonna hang onto it too make sure it doesn't break and it is in fact the wrong clip and then if it drives fine I'll return it
Old 10-23-2015, 03:23 PM   #23
keeney35's Avatar
Also here's pics of it in thereClick image for larger version
Name:	ImageUploadedByMustang Evolution1445635374.555532.jpg
ID:	192693Click image for larger version
Name:	ImageUploadedByMustang Evolution1445635388.254828.jpg
Old 10-26-2015, 02:32 PM   #24
keeney35's Avatar
Got her done Click image for larger version
Name:	ImageUploadedByMustang Evolution1445891520.246477.jpg
ID:	192907Click image for larger version
Name:	ImageUploadedByMustang Evolution1445891539.273026.jpg
Old 10-26-2015, 02:38 PM   #25
Slater2111's Avatar
Nice! Now take her out and light the tires.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
rebuilding rearend Senorjizzy Pre-2005 V6 Mustang 6 08-08-2009 06:16 PM
Rebuilding the Ford 3.8 Kiljosh Pre-2005 V6 Mustang 1 06-12-2006 01:12 AM
rebuilding a rear Tbird232ci 1979-1995 Mustang GT 8 11-15-2004 10:18 AM
rebuilding engine and twin turboing tek55 Pre-2005 V6 Mustang 20 03-26-2004 12:38 PM
what rebuilding to do to used m90 tire Pre-2005 V6 Mustang 4 03-26-2004 11:20 AM
06:13 PM
