04 cobra fuel tank swap - Mustang Evolution
Old 10-21-2015, 04:50 PM   #1
TxHxE MadHatter's Avatar
Sooooooo I'm in the middle of my cobra swap into the 01 GT, I took the tank down and swapped it entirely for the cobra tank- but when putting it back up I noticed something that worries me.. One of the fuel lines that normally attatched about 4-5 inches to the left of the exhaust pipe if ur looking directly up at it.... The connection for it is located almost directly behind the exhaust pipe on the cobra tank.Click image for larger version
Name:	ImageUploadedByMustang Evolution1445467624.799337.jpg
ID:	192627Click image for larger version
Name:	ImageUploadedByMustang Evolution1445467647.219439.jpg
So my question is should I just try to swap the lines from the top of the GT tank and put them onto the cobra tank to relocated the connection point back to where it was originally? Or would that not work? Any help is appreciated
TxHxE MadHatter is offline   Reply With Quote
Old 10-21-2015, 05:22 PM   #2
Fuel vapor tube* not fuel line my bad
Old 10-21-2015, 09:07 PM   #3
Yes you need to swap the vents from your old tank. Be very careful not to break them as you remove them. They may require a good amount of force to get them out.
Old 10-21-2015, 10:58 PM   #4
Thanks, I was pretty sure that would end up being the case.. And I've heard a bunch of ppl talk about how much of a PITA those vents are to change without breaking them so that should be a fun time
96 Cobra Fuel Tank & Straps robb15033 1996-2004 Mustang GT 15 05-29-2015 01:21 AM
Cobra fuel tank ? 2002VertGT SVT Mustang 4 01-11-2014 09:47 PM
trade brand new corbeau seats for 03-04 cobra tank fuel pump assembly Tomb1987 1996-2004 Mustang GT 9 05-19-2013 04:46 PM
Carb swap fuel tank sump? 87fox 1979-1995 Mustang GT 0 04-15-2013 07:52 PM
Fuel Tank Swap out for 1979 Mustang? jeannot 1979-1995 Mustang GT 3 08-17-2009 11:24 PM
04:44 PM
