N2mb install help - Mustang Evolution
Old 10-21-2015, 10:17 PM   #1
SkylerTallman_'s Avatar
N2mb install help
Hey guys, I just got my n2mb wot box in the mail for my 2004 Gt and I want to attempt it by myself and have read the directions a couple times and think i know what I'm doing. I do want to clarify a few things though, going to sound like a dumbass. 🙈 but I've never have done any wiring. So when I splice a wot box wire into a harness, do I just connect it to the harness wire I'm using or replace part of it? I'm assuming I just strip some of the rubber off and tie all the wires together and solder and heat wrap.
And on the last step where you connect it to the coil packs and ignition, is there a certain place it has to be on the wire other than just close to the end?
Thanks! Any tips at all on the install will be much appreciated, sorry for dumb questions but it's better to be safe than sorry.
SkylerTallman_ is offline   Reply With Quote
Old 10-21-2015, 10:47 PM   #2
retiredvet's Avatar
Im not sure about what your doing but here is a general electrical pro tip. Dont cut, strip, and tape. Use quick splicers, thats their name can get them anywhere. Locks your wire right into existing wire no cutting, taping, splicing, etc
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 10-21-2015, 10:59 PM   #3
Thanks man! Are those reliable?? Assuming you use them. They just have a bad star rating when I looked them up.
Old 10-21-2015, 11:30 PM   #4
retiredvet's Avatar
I've used them for years on just about everything thats small gauge wire. Even on 24 volt humvee and 220ac. Get 3M ones bulk bag. Never run out of uses for them.
Old 10-22-2015, 05:21 AM   #5
Sweet! I appreciate it man!!
Old 10-22-2015, 05:45 AM   #6
I believe there is at least 1 wire you have to interrupt. It's been a few years, however.
Sent from my XT1045 using Tapatalk
Old 10-22-2015, 06:33 AM   #7
Mile high JDF's Avatar
And also tends to fail and cause poor connection issues. I haven't met any pros who use vampire clips to do electrical work
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-22-2015, 02:26 PM   #8
parkerz28's Avatar
Solder connections are the best especially with higher current and won't come apart
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 10-22-2015, 03:06 PM   #9
retiredvet's Avatar
Alright well ive used them forever with no issues. Just use them properly and don't use the cheap ones. For you saying no, have you actually had a quality one fail on you or is this more word of mouth.
Old 10-22-2015, 04:36 PM   #10
I've had them fail. They are quite easy to crimp too tight and break and I have also seen them start to gather some rust.
Old 10-22-2015, 07:49 PM   #11
retiredvet's Avatar
Ok, fair enough.
N2mb 2 step help Evolution SVT Mustang 0 08-09-2015 03:27 PM
N2MB WOT BOX TheBullittTeam 1996-2004 Mustang GT 0 07-07-2015 04:03 AM
N2MB WOT box vs. MSD 2 step Sterlingbeast5.0 2011-2014 Mustang GT 1 04-15-2015 09:18 AM
N2MB wot boxes slade95gt 1979-1995 Mustang GT 4 04-01-2014 10:57 AM
N2mb wot box/2step Southern stang 2005-2010 Mustang GT 5 12-06-2011 12:28 PM
11:36 AM
