Fuel pump upgrade - Mustang Evolution
Old 10-23-2015, 09:52 PM   #1
keeney35's Avatar
Fuel pump upgrade
I'm gonna upgrade the fuel pump very soon. I'm sure it's maxed out with the cams and new injectors so what's a good upgrade that is plug and play.. Just something I can put directly in to replace the old one?
Also will I need a retune with the new pump since it will pump more
04 GT: CAI, 3.73, Longtubes, Full exhaust, FR500 locker diff, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 10-23-2015, 10:09 PM   #2
parkerz28's Avatar
Boost a pump will be fine... You can data log a few pulls to see your fuel pump duty cycle.
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 10-23-2015, 10:15 PM   #3
keeney35's Avatar
I'm assuming my pump is the problem. I went to 47lb injectors (overkill I know but they were cheap and I have future plans) but MPT sent me a base tune and I'm getting a fuel rail pressure sensor code I'm thinking the fuel pump is maxed and it's messing with the sensor.. I still have to datalog it and send them the log so they can adjust fuel trims and everything and that alone might fix the issue but just incase I might as well upgrade the pump since it's more than likely factory
Old 10-23-2015, 10:16 PM   #4
Slater2111's Avatar
You can read fuel pump duty cycle from your X4. I have no idea what it should be at. But it wouldn't hurt to look before you go spending money on a new pump.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back,
3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 10-23-2015, 10:21 PM   #5
retiredvet's Avatar
I didnt bother to wait around. When I did my injectors I did my pump. Super cheap. http://www.lethalperformance.com/aem...FU5qfgod1aMOCA
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 10-23-2015, 10:33 PM   #6
Slater2111's Avatar
I believe the Ford Focus pump is a direct replacement and flows more than stock.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Fuel pump replace/upgrade The_Chech 1996-2004 Mustang GT 11 11-20-2014 01:23 PM
Fuel pump upgrade. FastEddie03GT 1996-2004 Mustang GT 1 10-27-2014 05:46 PM
Fuel pump upgrade? DtrMustang 2005-2010 Mustang GT 0 07-21-2013 07:44 PM
Fuel pump upgrade Terminator 2005-2010 Mustang GT 8 06-28-2013 08:50 AM
04 3.9 mustang Fuel pump upgrade Zebs5408 Pre-2005 V6 Mustang 3 03-28-2010 02:29 PM
04:22 AM
