LS SWAP HELP - Mustang Evolution
Old 10-27-2015, 12:15 PM   #1
LS SWAP HELP
My car was running great and then it started knocking badly!
My first thought was to replace it with a built 2V but now I think
an LS swap would be not only cheaper but give me more power?!
What parts will I need to do the LS swap and does anyone have any first hand experience?
BlackCar is offline   Reply With Quote
Old 10-27-2015, 06:34 PM   #2
keeney35's Avatar
Trolling?
I'm not sure too many of us like the ls guys.. Why not find a mark viii and use that 4v motor.. Build the bottom end of your 2v and spray the piss out of it
04 GT: CAI, 3.73, Longtubes, Full exhaust, FR500 locker diff, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 10-27-2015, 06:39 PM   #3
Rapinator126's Avatar
Definitely would not be cheaper to swap a LS in it
🍼and 🌽 fed coyote.
Old 10-27-2015, 06:47 PM   #4
keeney35's Avatar
If your gonna swap anything it better be a termi motor or coyote
Old 10-27-2015, 07:01 PM   #5
2JZ swap. Peoples reactions... Priceless.
Pick your poison.
Old 10-27-2015, 11:45 PM   #6
retiredvet's Avatar
Only ls swap if your doing a weekend track car and are serious OR if your ls swapping a fox body those are cake. You can do an auto ls swap for about 1200 but just grab u a 500 dollar junkyard 2v and replace the one thats knocking. May even break even after selling parts
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 10-28-2015, 05:21 AM   #7
fenixignition's Avatar
the motor may be cheaper, maybe. but the 4.6's are already pretty cheap and easy to get. but the swap will likely be a pain. i'd imagine going from a ford to a gm, nothing will fit without fabrication.
2002 GT 5sp. 16x,xxx miles
Old 10-28-2015, 06:07 PM   #8
fomoco4life's Avatar
Find a crown Vic, swap motor, done. Stop with the sacrilegious talk, ur killing me
Old 10-29-2015, 11:29 PM   #9
96CobraJet's Avatar
All I did way a pi head swap and some juice and my 96 was a completely different animal
96CobraJet is offline   Reply With Quote
Old 10-30-2015, 12:40 AM   #10
alecas447's Avatar
New account and one post, obvious troll is obvious
alecas447 is offline   Reply With Quote
Old 11-04-2015, 11:15 AM   #11
Speed_Mister's Avatar
Region: Arkansas
Ls are not cheaper... Cheapest set of headers for ls2 my friend found were pacesetters for ~$500... Only cheap part is only one cam to buy which is around $300...
2004 Mustang GT 5 Speed Full Bolt Ons 385rwhp 450rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 11-06-2015, 12:34 PM   #12
thyreaper's Avatar
LS SWAP HELP
When u come to a ford forum and talk about throwing in a chevy motor u are gonna run into some ppl hatin on it and vice versa... Im not biased and say if u wanna do it go for it u need a motor,trans, eng harness and computer... The stock 4.6 mounts can be modified to work, ur gonna need the yoke from the gm driveshaft for transmission.. And theres always gonna be odds and ends and wiring to get the tach and speedo and oil press and all to work... Ls swap headers... Better off goin to ls swap forums tho cuz here ur gonna get pushbacks because hardcore ford enthusiast dont like that stuff... It would be cheaper to pull a crown vic jy motor and throw in there trust me on that... And u can make good hp n.a with the ls motors as to where it cost a fortune to get 370hp n.a with the 2v.. But u can boost the 2v and dust the ls cars as long as they arnt sprayed or boosted and spend less then building a 500hp ls motor.. It really depends on what are ur goals, if u ever plan on boost or spray then just make the 2v tough with some forged parts and do it but if ur gonna always stay n.a ull make more power n.a with a ls motor then with a 2v.. So what are ur final goals?
thyreaper is offline   Reply With Quote
t5 swap... Trans broken after 800 miles HELP HELP flatstanley1 1979-1995 Mustang GT 11 01-17-2014 08:39 PM
Engine swap 3.8L to 4.6L NEED HELP!!!! PonDog15 Pre-2005 V6 Mustang 23 06-29-2010 08:43 PM
To Swap, or not to swap...... Strongarm 1979-1995 Mustang GT 5 02-05-2008 01:39 PM
Cam Swap... stuck, any help? Invictus 1996-2004 Mustang GT 21 12-28-2006 09:29 PM
Need some help with my HCI swap Kiljosh Pre-2005 V6 Mustang 11 10-09-2005 06:34 PM
02:56 AM
