K member - Mustang Evolution
Old 10-28-2015, 10:59 AM   #1
XxFLoridaboYxX's Avatar
K member
About to order a upr k member which one do I need 14" 175lb springs or 12" 200lb springs.. I shouldn't have a problem clearing my 9.5" rims with coil overs ? The plan is to go with the on3 kit this winter .
XxFLoridaboYxX is offline   Reply With Quote
Old 10-28-2015, 03:03 PM   #2
bwright1973's Avatar
You will not be disappointed in the kit power wise!!!! Watched a non pi motor yesterday pump out almost 440hp on 9.5 psi. Tuner was quickly backing some boost off to get it back around 400 at the wheels. That was a 100% stock car other than some exhaust
bwright1973 is offline   Reply With Quote
Old 10-28-2015, 05:21 PM   #3
I'd go with the 200lb springs, too soft and it can feel a bit loose on the street. To give you an idea, i run 375lb up front, but its more of a handling set up.
Old 10-28-2015, 05:34 PM   #4
Wow 375 that has to ride rough!!!
Old 10-28-2015, 05:39 PM   #5
Alright I'll go with the heavy spring. The 14" or 12" won't make a difference?
Old 10-28-2015, 06:41 PM   #6
Very lol
Old 10-30-2015, 06:09 PM   #7
I need to also replace the studs and get some locking nuts for the headers . Where would I order the correct parts from ? It has bolts there now That the previous owner installed
Old 11-04-2015, 12:07 PM   #8
I've heard that running coil overs on the street sucks ?
Old 11-04-2015, 01:44 PM   #9
robin_gt's Avatar
I have upr coilovers with the 12 inch 250 lb springs and the ride quality is similar if not identical to my previous h&r springs.
robin_gt is offline   Reply With Quote
Old 11-04-2015, 02:34 PM   #10
It depends on a lot of factors.... Spring rates, how low you go, whether or not you hit the bumpstops like I do.
New Member (pics of my car) *DUW* Concordium The Bar 12 03-23-2004 05:27 AM
New Member Here! LuvMyGT The Bar 12 03-09-2004 06:09 PM
Good k-member Black00GT Pre-2005 V6 Mustang 4 03-05-2004 12:50 PM
New Member GSRGuy18 The Bar 22 09-06-2003 08:02 PM
member "vee6" Rellik The Bar 0 07-17-2003 09:24 AM
10:07 PM
