Going from NA to Boost 15+ psi - Mustang Evolution
Old 10-29-2015, 11:25 PM   #1
96CobraJet's Avatar
Ok here we go the list of what I have
Clutch,trans, driveshaft, diff and axles have been upgraded
Body has been stiffened as well
Alum. Block
Cobra crank
Mmr rods
Mmr 16cc notched pistons
patriot stage 2 heads with valve job
Vodoo stage 2 supercharge cams
Mmr adj. timing set with timing tool
stock Pi intake with 78mm bb TB*
90mm SCT MAF meter
Vortech V1 S-TRIM*
snow ball meth. Kit*
Cm air to air intercooler*
OK now here is my question what else do I need.....
I know I need injectors but how big and I know I need a fuel pump then again how big and maybe a Boost A pump...
my goal is 600hp at the rear tires with an E85 tune so what pulley do I need as well thank you
96CobraJet is offline   Reply With Quote
Old 10-30-2015, 02:39 PM   #2
With all those mods and a pulley that will make 15psi+ I'm sure you will overshoot your 600mark. Especially if you're planning on using E85. I'd do the entire fuel system with a FORE set-up. Run twin lightning fuel pumps or GT500 pumps and some ID1000 injectors. That should flow more fuel than you car will be able to use at that power level.
I run ID1300s on my 2014, but I had ID1000s and they weren't even close to running out of fuel at mid 600s at the wheels. I switched to ID1300s because I run primarily E85 in the car and the ID1300s are a completely stainless steel injector and the E85 can not wear them out.
Going to trade in for eco-boost next year Deerslayer 2011-2014 Mustang GT 3 01-12-2015 03:05 PM
Max boost psi for stock 2.3 head 93mstnglx 2.3 Mustang 0 11-21-2012 04:56 PM
Boost line for boost gauge TooSlow4U 2011-2014 Mustang GT 0 07-20-2012 09:34 PM
9 psi super charger oaktonarcher Pre-2005 V6 Mustang 1 02-03-2004 11:45 AM
why would modest psi and 35 shot be so bad on stock motor? tire Pre-2005 V6 Mustang 14 12-21-2003 10:41 PM
11:50 PM
