Ticking/clicking - Mustang Evolution
Old 11-01-2015, 01:59 PM   #1
Jay180's Avatar
Ticking/clicking
So from a cold start my engine makes a loud clicking or ticking sound then once it warms up the sound goes from little to nothing. What could it be? I'm also running lean if that helps
Jay180 is offline   Reply With Quote
Old 11-01-2015, 02:57 PM   #2
Kevin.Cook
Guest
Posts: n/a
Does your car have an aftermarket tune or intake? Have you tried fuel system cleaner and checking fuel filter? Have you tried oil for high mileage vehicles?
Just running over the basics, sorry if it seems redundant.
Old 11-01-2015, 03:51 PM   #3
Slater2111's Avatar
It's the lifters most likely.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 11-01-2015, 04:27 PM   #4
Slater2111's Avatar
Ticking/clicking
Double post
Old 11-01-2015, 07:39 PM   #5
fwalck's Avatar
It could also be an exhaust leak like a blow exhaust manifold gasket or cracked manifold
fwalck is offline   Reply With Quote
Old 11-01-2015, 09:32 PM   #6
Jay180's Avatar
I've cleaned the maf sensor and the filter and I put a new fuel filter. It doesn't have any tunes. If it's the lifters how could I fix it? It Barely had an oil change less than 100 miles. And has 158k miles
Old 11-01-2015, 09:33 PM   #7
Jay180's Avatar
The only cleaner I've added is upper cylinder lubricant/ injector cleaner.
Old 11-02-2015, 03:46 AM   #8
Slater2111's Avatar
You really can't fix them other than replace if in fact that's it. Mine does the same thing except it is gone in a second. As soon as oil pressure fills the lifter it's inflated again and all is well. Kinda sounds like the same as yours. But it is worse. Just my guess don't freak out yet.
Old 11-02-2015, 08:35 AM   #9
Jay180's Avatar
I see people saying it could be a knock, lifter, timing tensioner, exhaust leak
Old 11-02-2015, 08:45 AM   #10
Kevin.Cook
Guest
Posts: n/a
Unfortunately, noises in general is hard, if not impossible to diagnose remotely. All we can do is give our advice from personal experiences. Of course there 2 routes to take. 1) throw random fixes at your car and hope the noises go away or 2) take it in for inspection at a shop and it can be pinpointed alot quicker/better as they will have it in person.
Weird clicking/ticking noise Notjust4boyz 2011-2014 V6 Mustang 12 10-29-2012 12:16 PM
"Clicking" or "Ticking" After Loading Tune illestdomer2005 Pre-2005 V6 Mustang 15 08-19-2011 10:44 AM
Help..Clicking Noise..V-6. Davor88 Pre-2005 V6 Mustang 19 12-05-2006 08:14 PM
Clicking sounds when depressed brake pedal jaynez31 New Member Introductions & Greetings 2 11-30-2005 08:01 PM
Motor clicking when 1st started... RuddFan Pre-2005 V6 Mustang 7 11-27-2005 01:57 AM
09:04 PM
