How Do You Store Your New Edge - Mustang Evolution
Old 11-02-2015, 07:34 PM   #1
jjsg09's Avatar
It's getting close for me to store my Stang away for the winter just was wanting to know how everyone goes about it step by step.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 11-02-2015, 10:06 PM   #2
BeastyStang's Avatar
Though our weather isn't "bad" out here. I always detail inside out real well, then put the car cover over it then check up on it every other day to see if dust is building up lol.
BeastyStang is offline   Reply With Quote
Old 11-02-2015, 10:39 PM   #3
Give it a good wash. Drive to the storage facility. Throw a cover in top. Probably should disconnect the battery but I don't think it's necessary
Alewan_02_GT is offline   Reply With Quote
Old 11-03-2015, 12:24 AM   #4
Steve96's Avatar
Good cleaning, i usually change oil then change it again in the spring, fill up the gas tank or use stabil, battery tender, car cover, and wait out the winter.
---------- Post added at 02:24 AM ---------- Previous post was at 02:23 AM ----------
Their not sitting that long so no need to go over board really
1996 GT
Old 11-03-2015, 10:42 AM   #5
RBK
I stored mine for one year when I lived in MN. Fill up the tank and put in Stabil. Get a battery tender to keep the battery charged. Mine was in my garage so I started it every couple of week and let it run for 15 minutes, more just to hear it than anything else. I purchased a top of the line car cover, for indoor use only. and still have it if you are interested in buying one, it's like new.
RBK is offline   Reply With Quote
Old 11-03-2015, 02:09 PM   #6
parkerz28's Avatar
I moved to Florida... Solved my storing issues I had in Michigan lol
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 11-03-2015, 03:33 PM   #7
I live in Cali where it's sunny almost year round lol. I keep it stored though. It's my second car and I don't get to drive as much as i'd like to. But it sure looks great in the garage lol.
Old 11-03-2015, 05:58 PM   #8
Clean her up real good inside and out...some dryer sheets on the inside to keep critters out and disconnect the negative battery cable only. You won't have any issues and I live in the cold wasreland that is upstate NY.
Vinnie02 is offline   Reply With Quote
Old 11-03-2015, 11:57 PM   #9
Steve96's Avatar
Best recommendation so far. Screw Mi weather! Good choice!
1996 GT
Old 11-04-2015, 04:41 AM   #10
Strange Mud's Avatar
what I do for 3/4 months detached unheated in CT
put in Stabil (use the funnel!!!) than add premium to full. run for minimum of 10 minutes to distribute.
Clean car
I park on folded up cardboard with 5 extra psi. Flat spots are more from the past but easy/free
cover cowl intake and exhaust with painters tape (critters)
either a commercially available "Mouse Magic" or what I do is cotton balls with a mix of spearmint/peppermint oil (same as MM) replaced 1x month
leave hand brake off
either a battery tender or charge for a few hrs 1x month
I pull fuel pump relay/fuse before starting after storage to prime oil pump (I do NOT start during storage.
your OLM will count time during storage remember this and change oil accordingly. if it'll need it in January I would change it now.
cover it.
Make vroom vroom noises for 6 months.
most of this is not important but stable and battery are. Others won't do anything, others will drive all winter.
you can skip the part about the funnel, I just copied/pasted from another thread....also I wash beforehand and cover it with a Burge cover from WallyMart <$75 made in USA.
Strange Mud is online now   Reply With Quote
Old 11-05-2015, 05:51 PM   #11
superdrift's Avatar
Sadly i dont have this luxury and have to daily drive mine
superdrift is offline   Reply With Quote
Old 11-09-2015, 09:54 AM   #12
Lorraine's driver
ab_mach1's Avatar
Dang man, I thought you sold your newedge a year or more ago. Glad you still have it! I may have to put min in hibernation because we've had bad winters for the past few years here in Indy. I'm sure you can relate.
Instagram: @ab_mach1
new edge
Post up walk around video of you new edge! DetroitMuscle99 1996-2004 Mustang GT 3 05-20-2015 05:51 PM
Do you store the mustang in winter? mustangz General Mustang Discussion 35 11-14-2013 05:30 PM
new husbands Store has opened in NYC Herbstang The Bar 6 01-24-2008 10:11 AM
Whats your favorite auto part store? SpectorV The Bar 19 05-25-2006 09:22 AM
possible new products for the store!! 97Stallion The Bar 0 11-24-2004 10:12 PM
08:20 AM
