4:10s? - Mustang Evolution
Old 11-05-2015, 10:04 AM   #1
4:10s?
I am currently thinking about putting new gears in my 2004 Mustang GT to wake it up. I'll most likely get 4:10s or 3:73. What should I expect on the doing around 70 on the highway and 55 down the country roads.
Austin0025 is offline   Reply With Quote
Old 11-05-2015, 10:50 AM   #2
Auto or manual. Normally recommend 4.10 for auto and 3.73 for manual.
With that said I really like gear and have 4.10's in 2 of my cars.
Sent from my XT1045 using Tapatalk
Old 11-05-2015, 10:54 AM   #3
Slater2111's Avatar
I have an auto and wish I had gone 4.10. 3.73s are better than stock, but the extra pep would be nice with the 4.10s. The overdrive of the auto is enough you won't suffer too much in gas mileage.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 11-05-2015, 11:00 AM   #4
It is a Manual
Old 11-05-2015, 11:29 AM   #5
quadesiverling's Avatar
Not that big of a difference only like 200 rpm difference but if you drive a lot of freeway don't get 4.10s
quadesiverling is offline   Reply With Quote
Old 11-05-2015, 11:34 AM   #6
XSlashDashX's Avatar
Go with 4.10s.
Old 11-05-2015, 07:33 PM   #7
4.10s with a 26" tire and the .62 overdrive ratio will do 2300rpm at 70mph, and 1800 at 55mph in 5th also.
Old 11-05-2015, 11:09 PM   #8
Steve96's Avatar
Go 410!! in overdrive you will be ok, around 2300 with your car. Dont let a couple hundred rpm dictate the performance feel and advantage of the 410s. Many on here have gone 373 and wished they had done 410s. If doing it make it worth while IMO
1996 GT
Old 11-06-2015, 08:16 AM   #9
4.10s. If you are worried about a few hundred RPM on the highway go buy a Prius.
The 02-04 manuals had a .62 overdrive, Soccer's numbers are accurate. You can also jump up to a 26.7 or even 27" tire if you aren't lowered too much and get an even lower highway RPM. Plus it fills up your wheel wells. I ran a 275/40/18 on a 18x10 on my blue 98 which is a 26.7" tall tire.
Old 11-06-2015, 08:30 AM   #10
Thanks Guys, Definitely going with the 4:10s
Another 4.10s and T-Lok question soon2bfastr232 Pre-2005 V6 Mustang 15 02-08-2005 08:38 PM
tq converter and a set of 4.10s oaktonarcher Pre-2005 V6 Mustang 14 10-26-2004 09:50 PM
8.8" w/ 4.10s + T-Lok Laser02 Pre-2005 V6 Mustang 1 04-04-2004 02:50 PM
V6 TT claims he is in the 10s any one heard of him.... SpectorV The Bar 14 12-14-2003 12:43 PM
4.10s are officially in!! tire The Bar 5 07-14-2003 11:50 PM
09:59 AM
