Throttle body/plenum for fi car - Mustang Evolution
Old 11-06-2015, 02:45 PM   #1
I have a vortech supercharger with a stock throttle body and plenum. Am I leaving out a decent amount of horsepower because my car is fi?
If so, which size and brand do you recommend?
Quadracer18 is offline   Reply With Quote
Old 11-06-2015, 05:05 PM   #2
parkerz28's Avatar
No... Unless you have a built motor running lots of boost
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 11-06-2015, 05:11 PM   #3
Slater2111's Avatar
I disagree. Even with a NA car I noticed a lot of untapped potential when I went aftermarket and much bigger. Hell. The second time around with my TB I went bigger and noticed a little more. My recommendation is to get a C&L plenum and a summit 75mm TB. Or just a summit TB and plenum combo.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 11-06-2015, 05:14 PM   #4
parkerz28's Avatar
Not worth the money... Even a basic supercharger setup will put you close to what the stock bottom end will hold... Better off spending the money in an intercooled setup
Old 11-06-2015, 05:16 PM   #5
Slater2111's Avatar
This is very true.
Old 11-06-2015, 05:19 PM   #6
parkerz28's Avatar
I'm at 400 whp with stock plenum and throttle body... Gains could be made but since he is boosted I wouldn't spend the extra money on it but that's just me... If he listed his entire setup I guarantee that's one of the last things I would be worried about
Old 11-06-2015, 05:21 PM   #7
parkerz28's Avatar
Still love you though slater 😍😘
Old 11-06-2015, 05:53 PM   #8
Slater2111's Avatar
But if he built that bottom end the potential is there.
Old 11-06-2015, 06:01 PM   #9
I'm going to do a TFS plenum and Summit TB because I can... and I'm getting blower cams and would like all I can get out of it before the boost comes on...but not expecting anything drastic over what the stock would be as far as peak power. I just don't like the idea of a wall of air going through a 3" tube the whole way and then smacking into a metal lip going into the intake. 3" is about 75-78mm so getting one of those on there is a nice smooth route the whole way.
Old 11-06-2015, 09:26 PM   #10
Slater2111's Avatar
My thoughts exactly on my reasoning. Have you seen the inside of the C&L plenum vs the trick flow? It's a very smooth transition. I haven't compared the two but I've been impressed with mine since it went on.
Old 11-07-2015, 05:31 AM   #11
The Trick Flow is smooth too and flows just about as well as the Accufab for like... half the cost. Summit owns Trick Flow anyway so the Summit TB is just a de-branded TFS unit. Also the reason you cannot buy TFS products from Jegs.
Old 11-07-2015, 09:48 AM   #12
torchdNblazen03's Avatar
So the summit TB would be just as good as the accufab ? And what about the big 78 mm bbk makes ? Just a thought because I've heard mixed feelings on them
torchdNblazen03 is offline   Reply With Quote
Old 11-07-2015, 12:57 PM   #13
Slater2111's Avatar
Don't bother with them.
Old 11-07-2015, 03:21 PM   #14
The BBK piece is ok... just ok. There was a pretty legit test done awhile back of all the plenums and the Accufab was the best followed REALLY closely by the TFS. I just don't like the way the BBK looks and the giant "BBK" is the first thing your eyes set on when the hood opens. At least that's my experience. Since I'm not a fan of BBK in general, definitely don't want to be advertising for them.
Old 11-07-2015, 05:13 PM   #15
Yeah I defiantly agree.. I'm not a huge BBK fan myself, I've just read that a lot of ppl actually like this piece.. As my next mod will be a tb an plenum I need a little bit of advise on this as well..
Old 11-07-2015, 05:14 PM   #16
75mm ? Do they have one in that size.
Sent from my SM-G360P using Mustang Evolution mobile app
Bullittone is offline   Reply With Quote
Accufab throttle body and plenum Mzilla Mustang Parts for Sale and Wanted 1 06-30-2012 04:12 PM
Throttle Body And Plenum 1lowGT 1996-2004 Mustang GT 22 03-25-2012 02:59 PM
What Throttle Body/Plenum Combo Should I Get? TheJigShow 1996-2004 Mustang GT 11 08-29-2011 11:41 AM
75mm Plenum/Throttle Body installed Thomas91169 1996-2004 Mustang GT 20 10-18-2005 06:28 PM
Stock 2002 GT Throttle Body and Plenum...End today Junior2561 Mustang Parts for Sale and Wanted 0 02-23-2004 07:08 AM
09:34 PM
