Spring chopping. - Mustang Evolution
Old 11-06-2015, 06:30 PM   #1
Spring chopping.
Hey guys! I have my 2002 mustang and I am having a little issue. Awhile back I bought some sr lowering springs and I accidentally put the rears in the front. I switched them out put everything in order. But my problem is that the rear is 3/4 inch lower than the front, and very noticeable to me. I'm not sure if the time in the front squished the rears I donno. But I like where the rears are at I just think the front is a touch too high. So that being said, any opinions on cutting the fronts just a bit to lowering it back to even? Thanks!
wawanesa5speed is offline   Reply With Quote
Old 11-06-2015, 08:10 PM   #2
How long were the rear springs up front?
Old 11-06-2015, 09:16 PM   #3
What do you mean?
Old 11-06-2015, 11:30 PM   #4
Steve96's Avatar
I think he means "how long were the rear springs on the front?". Like a week, 2 weeks, a month? I would think they could be a little compressed. Why dont you do Steeda X2 ball joints up front, and leave out the isolators and no cutting of your springs? Cost a little more of course but then you will have the Steeda ball joints. Doing that should be close to 3/4" total.
1996 GT
Old 11-06-2015, 11:36 PM   #5
They were in for about a week. And i just want to get this done with no cost. Seems like an easy fix just to cut the spring, doesnt change how it seats at all.
Old 11-06-2015, 11:37 PM   #6
Steve96's Avatar
Only a week, i wouldnt think that would be long enough to permanently compress them. Look up how to cut them, cut as little off as possible and reinstall without the isos
1996 GT
Old 11-07-2015, 12:18 AM   #7
Senior Member
thebayareapimp's Avatar
I think it's just your imagination
Sent from my iPad using Tapatalk
thebayareapimp is offline   Reply With Quote
Old 11-07-2015, 12:23 AM   #8
I measured at the front tire fender gap is 3/4 higher. And its noticable haha. Wish i could post pics but cars in storage!
Old 11-07-2015, 12:24 AM   #9
Senior Member
Ya, pictures would help for sure. Why is it storage?
Old 11-07-2015, 01:06 AM   #10
Do not forget the "XR"balljoints! Today!!
Old 11-07-2015, 12:32 PM   #11
Because i live in northern canada and its almlst winter lol
Old 11-07-2015, 01:13 PM   #12
keeney35's Avatar
Steeda x2 ball joints are a must plus they will lower the front some... If the tires are different sizes the gap will be different too
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 11-07-2015, 03:10 PM   #13
Tires are the same size. Ill probably just cut the springs abit. Ball joints are a good idea ill get those as well
Old 11-07-2015, 03:43 PM   #14
Strange Mud's Avatar
it can be done....I'll be the 1st to suggest not to.
Old 11-07-2015, 05:24 PM   #15
What would you suggest for lowering the front of my car 3/4 an inch and why do you not recommend it?
Old 11-07-2015, 05:44 PM   #16
Project Pony's Avatar
I'll be the second. Get the steeda X2's. Also did you put the spring iso's back in? You could remove them from the front, replace the rear with new ones, and grab the X2's and that should take care of your problem.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 11-07-2015, 06:40 PM   #17
keeney35's Avatar
Do the ball joints and remove those and I bet it fixes it without chopping springs
Old 11-07-2015, 06:50 PM   #18
Post up some pictures. If the springs are ruined then cutting them will only make them worse.
It is a ton more weight on the front than the rear. Putting those soft springs up front aren't that great for them.
Old 11-07-2015, 06:59 PM   #19
parkerz28's Avatar
Park on level ground and post some pics... Without any pics we are just guessing
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 11-07-2015, 07:31 PM   #20
Steve96's Avatar
This was already suggested a while back, he said he wants to do it without spending any money. But i think this is the best route
1996 GT
Old 11-08-2015, 04:41 AM   #21
it's cutting of springs that isn't the best. getting them to sit right afterwards (even and securely) for something that is critical to the handling of your car.
Old 11-08-2015, 06:40 AM   #22
thyreaper's Avatar
U shouldnt cut new springs at all and if they are a progressive rate spring cutting it will ruin it to where u cant even drive it... Somethings done happen the front isos may be there but rears not ( like a forget type of thing) or maybe it did bend them some if they bent id try n see if they would exchange it ( i wouldnt say they where improperly installed to them ) most companies will exchange them just to keep a customer happy and coming back anyways... But take a pic of ur car and we can give better suggestions on how to fix... I wouldnt cut the springs if its bothering u that bad u could cut the stockers and put back in untill u can get replacements but i wouldnt cut a aftermarket spring..
thyreaper is offline   Reply With Quote
Old 11-08-2015, 11:41 AM   #23
I liked having the isolators in there. Dont i need them to prevent any noise?
Old 11-08-2015, 10:31 PM   #24
Steve96's Avatar
You can wrap the bottom of the springs with a heavy duty electrical tape or ive seen people take a bike intertube and slice it and wrap it around the bottom for some cushion.
1996 GT
Old 11-09-2015, 01:17 AM   #25
I think ill just chop sounds easier 😜
Old 11-26-2015, 03:06 PM   #26
Did you purchase and install new springs?
I am selling my brand new suspension system parts, if interested, let me know
Spring compressor for strut/shock spring installation liv4spd 2011-2014 V6 Mustang 9 07-23-2015 11:21 PM
Lowering Spring Installation - No Spring Compressor?? Mean14 2011-2014 V6 Mustang 12 05-22-2015 12:48 AM
Chopping springs Mile high JDF 1996-2004 Mustang GT 7 02-08-2012 05:16 PM
stock spring spring Scut95 1979-1995 Mustang GT 2 09-15-2005 04:11 PM
Spring install aggiesarge Pre-2005 V6 Mustang 30 08-05-2003 07:39 PM
12:33 AM
