radiator fan always on - Mustang Evolution
Old 11-08-2015, 11:56 AM   #1
robin_gt's Avatar
hey
i just noticed that the radiator fan is constantly running on my 2002 mustang gt, in the morning when the car is cold and when the car is warm. Should i be worried? i just dont want to run into any problems down the road. What are some basic things to check? thanks
robin_gt is offline   Reply With Quote
Old 11-08-2015, 07:12 PM   #2
fenixignition's Avatar
is your a/c on?
2002 GT 5sp. 16x,xxx miles
Old 11-08-2015, 07:14 PM   #3
robin_gt's Avatar
Originally Posted by fenixignition View Post
is your a/c on?
Yes
Old 11-10-2015, 05:07 AM   #4
Ogre's Avatar
If your a/c is on, your fan will constantly run. Turn it off and see what happens.
Ogre is offline   Reply With Quote
Old 11-11-2015, 08:22 PM   #5
Will run if defrost on too,as the a/c is running anytime defrost is on
ALLYDRIVER1 is offline   Reply With Quote
Old 11-12-2015, 11:11 AM   #6
You can check the fan relay to make sure it is turning on and off. You could have a relay that is stuck on which would cause the fun to run anytime you have ignition on.
Old 11-12-2015, 07:30 PM   #7
JOberlander's Avatar
Another thing that this might point to due to the age of the car is that the bottom half of the radiator is full of sludge and minerals. How quickly does the car get hot?
JOberlander is offline   Reply With Quote
Old 11-12-2015, 10:12 PM   #8
Originally Posted by zlwhat View Post
you can check the fan relay to make sure it is turning on and off. You could have a relay that is stuck on which would cause the fun to run anytime you have ignition on.
Sent from my iphone using mustang evolution
or you could just turn off a/c and defrost before starting car. If the fan doesn't come on when you start engine problem solved , no problem.
Radiator Cooling Fan is ALWAYS on crazybox1918 1996-2004 Mustang GT 7 01-11-2014 09:30 AM
Electric fan on a 5.0 or stock fan? Haav 1979-1995 Mustang GT 8 07-10-2012 07:34 PM
05:58 AM
