Top end - Mustang Evolution
Old 11-09-2015, 07:03 PM   #1
001Gt's Avatar
Top end
How can I gain more top end?
What are some good moods that will help me?
2001GT slow_2V
001Gt is offline   Reply With Quote
Old 11-09-2015, 07:26 PM   #2
Rosariors3's Avatar
Changing ur gears would help
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 11-09-2015, 07:36 PM   #3
Gears help you come into the power band quicker and less resistance due to them being shorter.
If you want more revs and more actual power up top, throw in come cams.
Old 11-09-2015, 07:40 PM   #4
torchdNblazen03's Avatar
Cams... throttle body and plenum you will notice gains at a higher rpm
torchdNblazen03 is offline   Reply With Quote
Old 11-10-2015, 03:13 AM   #5
parkerz28's Avatar
Top end
Supercharger, turbo, nitrous
Any one of these should do the trickπŸ˜ŽπŸ‘πŸ»
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 11-10-2015, 07:15 AM   #6
There is not much you can bolt on to get more power out of the 4.6L engine wise. Exhaust and gears and then work on suspension and driveline mods. You will need major engine work and/or a power adder to hang with the newer cars.
Old 11-10-2015, 07:32 AM   #7
001Gt's Avatar
Top end
My car hangs with some newer cars . I have 3 inch exhaust .x pipe, slp loud mouth, upper control arms, shocks,springs, tires, plenum, throttle body, cold air, and a tuner ... I do great on digs it's the rolls that
Kill me...
2001GT slow_2V
Old 11-10-2015, 08:15 AM   #8
Kill me...
2001GT slow_2V
When I say newer cars I mean the Coyotes and that group. You might be able to stick close to a base one but one with a basic exhaust and tune will push in your butthole.
Old 11-10-2015, 09:36 AM   #9
001Gt's Avatar
Top end
I thought you meant other cars not 5.0s haha I only hang for like 4 secs and then they pull way hard!!! Haha
But that's only cause they spin tires more than I do ha
2001GT slow_2V
Old 11-10-2015, 12:05 PM   #10
Speed_Mister's Avatar
Region: Arkansas
Probably a turbo.
2004 Mustang GT 5 Speed
Full Bolt Ons
385rwhp 450rwtq
12.1 @ 117.9
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 11-10-2015, 12:36 PM   #11
Originally Posted by Speed_Mister View Post
Probably a turbo.
Full Bolt Ons
385rwhp 450rwtq
12.1 @ 117.9
Even with a power adder a stock 4.6L will have issues simply due to the low redline. I'm not under any illusions that my car when done at 425-450 will be able to hang with a bolt on/tune Coyote. I will probably surprise the **** out of a few tho.
Old 11-10-2015, 01:44 PM   #12
Swap in a coyote. Beat them with less power hahaha.
Old 11-10-2015, 01:47 PM   #13
thyreaper's Avatar
Thats what a cam/valve spring change is for πŸ˜‰ and my car i pull on the newer coyotes cuz stockers rwhp is around 380 which is very slightly lower then mine not to mention heavier... I dont blow there doors off but i do pull the whole time after first, my tires not awsome so first spins bad dam near useless atm ( rear tires have about 2/32 left)
thyreaper is offline   Reply With Quote
Old 11-10-2015, 02:14 PM   #14
Yeah talking about a stock rod motor. A full stroker build with power adder and the mods to properly support it plus the cost of the car is getting into the $20k range...
Sent from my LG-D801 using Mustang Evolution mobile app
Old 11-18-2015, 04:39 PM   #15
Region: Arkansas
2 Valves are not very good top end cars unless you want to open up the motor and forge at least pistons and rods and go for ~600rwhp on a power adder limiting the crankshaft... The only thing amazing on these cars is the torque that comes with it. Want more hp than torque and more top end? Then buy a 4v. 2 valves are good for dig racing, not so good for roll racing or top end for the most part. 4v's are good at Dig racing and good for rolls. (& more top end). Or buy an LS motor or LS car.
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9
Full Bolt Ons
370rwhp 470rwtq
Old 11-18-2015, 04:43 PM   #16
dave73's Avatar
There is no doubt that you can surprise a few especially if you have it setup right and get 100% of your power to the street. It's a lot easier to rip and grip than to back pedal. I've seen a 2v embarrass a GT 500 off the line before.
dave73 is offline   Reply With Quote
Old 11-18-2015, 04:47 PM   #17
Region: Arkansas
For the most part, but on the right setup you can. From where I'm from there are two full bolt on 5.0's a 2014 and a 2015 both full exhaust, intake, clutches, ghost cam, Lund tuned, stock heads, 2014 was running 10.0 at my track with drag radials and driver mod, which is what I run, and the '15 is running 10.2 @ like 104. I think I'm trapping a faster mph at 107.. I'm also Stock motor stock intake. Beat another bolt on 5.0 at another track. All ya need is an extra 125rwhp.
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9
Full Bolt Ons
370rwhp 470rwtq
Old 11-18-2015, 05:01 PM   #18
dave73's Avatar
Check this out it will give you something to shoot for.
Convertable top to hard top. Midknight26 1996-2004 Mustang GT 31 03-31-2013 02:28 PM
I have a 1991 mustang convertible with a eighty's top what top to buy? ? Keme 1979-1995 Mustang GT 1 12-11-2011 11:52 PM
help, 91 vert with 80's top frame? what top to buy? jmuddyman 1979-1995 Mustang GT 3 10-17-2011 02:22 PM
TOP END FOR SALE fasthatch302 Mustang Parts for Sale and Wanted 0 11-13-2006 02:34 PM
best mods for top end power MusclesFromBrussels Pre-2005 V6 Mustang 5 07-18-2003 10:54 AM
07:13 PM
