Clutch cable what to use ! - Mustang Evolution
Old 11-09-2015, 08:39 PM   #1
smsstang's Avatar
Okay I'm gonna be ordering a clutch cable this week and need to know which one to order . I had some trans work done and my mechanic said the clutch cable needs to be replaced and to get an adjustable quadrant ?
smsstang is offline   Reply With Quote
Old 11-09-2015, 08:47 PM   #2
OEM
Old 11-09-2015, 08:53 PM   #3
smsstang's Avatar
OEM
Can I get and adjustable quadrant if I use the oem?
Old 11-09-2015, 08:55 PM   #4
No real need. OEM cable with OEM quadrant is the best set up you will have.
Old 11-09-2015, 10:05 PM   #5
smsstang's Avatar
Okay if I got an OEM cable can I get a firewall clutch cable adjuster ? Would that be better to get than using the factory ?
Old 11-09-2015, 10:21 PM   #6
Link- To All You Need
Clutch Cable, Quadrant, and Firewall Adjuster Package
Old 11-09-2015, 11:32 PM   #7
Steve96's Avatar
It seems like everyone who goes aftermarket with the adjustable quaderant has issues lately. Been several threads recently that involve adjustment issues. But i have heard that Maximum Motorsports is as good as the OEM cables and their quaderant is good too. I would just stick with the OEM setup if it was me, no need to go aftermarket IMO
1996 GT
Old 11-10-2015, 06:55 PM   #8
Three Piece MM Kit Work Together
-Maximum Motorsports uses a Ford OEM that is slightly longer. They beef it up along the shielding (rubber gets super thick) that gets exposed to heat. Their quadrant takes the length into consideration for a smooth engagement, The firewall adjuster has a large range for throw out.
If you have longtubes, they have even more heat protection. But the clutch cable insulator is for everyone, working as the spacer between cable and bell housing to reduce heat soak.
LINK To Clutch Cable Heat Protection: Clutch Accessories
Drivetrain: Drivetrain
Their cable kit is in a class of its own.
Old 11-10-2015, 08:15 PM   #9
Oem only,anything other you will be sorry. Think about it, their are many original clutch cables out there working with no problem with over 200k on them
ALLYDRIVER1 is offline   Reply With Quote
Clutch or clutch cable acting up 99mustang99 1996-2004 Mustang GT 4 07-13-2013 12:38 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
What Oil Filters TO Use, And Not To Use JROC General Car Discussion 10 02-24-2007 08:19 AM
steeda clutch cable chipshot101 1996-2004 Mustang GT 3 04-24-2005 11:37 AM
started working on my cable clutch conversion fast64 Pictures and Videos 3 01-12-2005 09:52 PM
04:40 AM
