Keyless entry remote - Mustang Evolution
Old 11-11-2015, 07:25 AM   #1
BeastyStang's Avatar
I recently just purchased a new remote (shell) for my 02. The buttons on the old one were starting to stick. I switched everything over, but now my car won't lock or unlock. I tried to reprogram it, but that was a fail. Any idea on how i can get my remote to work again? Thanks!
BeastyStang is offline   Reply With Quote
Old 11-11-2015, 07:37 AM   #2
jeno's Avatar
Are you sure you it the battery in the correct way changing housings won't make it inoperable if it was working before
Sent from my 2003 rocketstang using Mustang Evolution
---------- Post added at 02:37 PM ---------- Previous post was at 02:36 PM ----------
Or bad battery
jeno is offline   Reply With Quote
Old 11-11-2015, 08:21 AM   #3
It came with a new battery. I placed it with the positive side facing down at first, then turned it around and nothing still. I even put my old battery and nothing.
Old 11-11-2015, 09:26 AM   #4
Slater2111's Avatar
I had a similar problem. The tabs on the circuit board for the battery that pushes it against the housing were weak and it wasn't making contact. I bent them out a little bit and all was well.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 11-12-2015, 07:16 AM   #5
Thanks for the tip! 👍🏽 i will be giving that a try.
Old 11-12-2015, 07:57 AM   #6
Slater2111's Avatar
Let us know if it work for you!
Old 11-12-2015, 02:16 PM   #7
Name:	ImageUploadedByMustang Evolution1447362965.447040.jpg
Is that sticky stuff around the buttons normal?
Old 11-12-2015, 03:12 PM   #8
Slater2111's Avatar
No I didn't see that on mine.
keyless entry quit working archer379 Pre-2005 V6 Mustang 7 09-19-2005 03:39 PM
installing keyless entry BuddyLee Mustang Audio & Video 24 05-20-2005 10:04 AM
Remote Keyless Entry natebest2000 Mustang Audio & Video 6 02-22-2005 11:32 PM
Aftermarket alarm system and OEM keyless entry question Crispy Pre-2005 V6 Mustang 2 02-28-2004 08:36 PM
Keyless Entry oldnavy638 Pre-2005 V6 Mustang 0 09-15-2003 06:19 AM
04:01 PM
