My build - Mustang Evolution
Old 11-15-2015, 12:23 PM   #1
bwright1973's Avatar
My build
Got my short block back!! Cobra crank eagle rods diamond Pistons arp 2000 bolts thru out! Dropped a set of heads off with same guy to get a little clean up work done! Now all I need is all the expensive stuff cams injectors mass air fuel system put it all in with my on3 single I've had two months now and I really hope to see high 600's maybe a 700 MAYBE!!
bwright1973 is offline   Reply With Quote
Old 11-15-2015, 12:24 PM   #2
And trying to decide on an intake!!! On gives big top end sacrifice bottom end other gives good low end and midrange!!! All being said this will be a daily driver so seems the intake is my biggest choice!
Old 11-15-2015, 12:36 PM   #3
Slater2111's Avatar
My build
If you're boosting, the eddy intake combo from modular head shop might be your best bet.
http://www.modularheadshop.com/mhsed...1999-2004.aspx
You'll sacrifice a little bottom end but once the turbo spools up it won't matter any more.
Cushman turbo cams would be would be nasty in it.
http://www.cushmanmotorsports.com/cm...-5-turbo-cams/
Don't forget to upgrade your valves and springs!
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 11-15-2015, 04:11 PM   #4
I have been looking at cams as well there's a lot of choices for sure but not many really slated for turbo. Not going to wild with the heads but want to make sure I can hit my number. 650 I'll be happy for a daily driven street car
Old 11-15-2015, 05:30 PM   #5
Slater2111's Avatar
With the right valves and springs that 2.5 turbo cam will be enough to hit that goal.
Need engine build(er) advice. PureVenom 1979-1995 Mustang GT 22 09-17-2005 11:37 AM
HELP need to build a cheap computer! SpectorV The Bar 4 08-14-2005 04:00 PM
Build a 3.8? FloMasta24 Pre-2005 V6 Mustang 7 03-07-2005 07:32 AM
Supercoupe Build Up Black95GT Pre-2005 V6 Mustang 11 01-03-2004 10:01 AM
build me a system Rellik Mustang Audio & Video 11 10-20-2003 11:42 AM
07:10 AM
