01 gt automatic will not come out of park - Mustang Evolution
Old 11-17-2015, 08:30 AM   #1
Ubnbit's Avatar
If the battery is uhooked and the key is turned on, it will shift fine. The car will start in neutral and allow you to shift to all gears. When you put it back in park, it is locked back up and will not come back out of park. What's the problem?
Old 11-17-2015, 10:01 AM   #2
04beautyGT's Avatar
I wish I could think of the name right now, but it sounds like the little solenoid on the back of the brake pedal. To confirm this, see if your brake lights are coming on when you hit the brakes...if they don't come on, there's your problem.
Sent from my LGL41C using Mustang Evolution mobile app
Sadie- '04 GT Auto- RMR#4837, 4-Point-SEXY
04beautyGT is offline   Reply With Quote
Old 11-17-2015, 12:04 PM   #3
04beautyGT's Avatar
Well, it's not a solenoid, but the brake light switch. This link is what I was talking about.
Old 11-17-2015, 05:10 PM   #4
Or the solonoid that locks the shifter in park, if brake lights work check if solonoid is getting power,if it is and not releasing the solonoid is bad
ALLYDRIVER1 is offline   Reply With Quote
Old 11-17-2015, 06:25 PM   #5
retiredvet's Avatar
Neutral safety switch. Mine went out on another car of mine near pikes peak in a blizzard after morning pt. I was a pissed off popsicle
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 11-17-2015, 08:26 PM   #6
Post
All of the above.
Start at the brake switch. If that, and the wiring and connector are in good shape, check for voltage at the shifter lock solenoid.
Old 11-17-2015, 08:28 PM   #7
It never happens at a good time...
Old 11-18-2015, 11:39 AM   #8
The same thing happen to my 94 GT and was the brake switch loosed wire.
fmlafo is offline   Reply With Quote
Old 11-18-2015, 01:05 PM   #9
Mustangs are bad to break the wires going to brake light switch .check your brake lights first and go from there
Old 11-19-2015, 07:39 PM   #10
Ubnbit's Avatar
Thanks guys!
Old 11-19-2015, 08:06 PM   #11
Bit, did you get a new edge?
Pick your poison.
Old 11-26-2015, 12:13 PM   #12
Ubnbit's Avatar
No, sorry brother. One of the guys I work with, his son has one. They had been working on it for a couple of days. I know they had trouble with it before with the active alarm. I kept thinking it was related to that. The guys on here nailed it tho. Thanks again guys.
Old 11-26-2015, 12:19 PM   #13
GrabberMeBlue's Avatar
Had this same problem on my '95 T/A. It happened as the weather got colder. The colder it was, the longer I would have to let the car run before I could shift out of park. Close to 10 minutes eventually, and also got to the point where it happened in warm weather. Once I did get it out of park, it was fine for the rest of the day.
Everyone was saying brake light switch. I had it in to the dealer and they couldn't figure it out. After a couple years of dealing with it, I found out there was a shifter solenoid switch under the console. I replaced that and has worked perfectly for the last 5 years.
I know it's a different car, but worth looking into whether you have a shifter solenoid switch also because the brake light switch took me down a dead path.
2012 Grabber Blue Mustang Convertible V6 Premium
1979 Solar Gold Trans Am
1995 Bright Red Trans Am Convertible
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 12-14-2015, 04:31 PM   #14
escottcarp's Avatar
My son had the same problem with his Altima. The problem was a blown fuse that controlled the brake light switch.
escottcarp is offline   Reply With Quote
HELP - stuck in Park and key won't come out mlh 2005-2010 V6 Mustang 1 06-01-2015 04:31 AM
Automatic stuck in park..Help? NeedSomeMods Pre-2005 V6 Mustang 5 04-12-2011 10:58 PM
Welcome to WWP Chaos come check it out we have a stacked card come c the action? jukka General Mustang Discussion 6 03-26-2010 10:04 PM
Women Can't Parallel Park (and something about Ford's Active Park Assist) OsirisGuy The Bar 8 09-24-2009 09:03 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
02:25 AM
