Car shuts down by its self - Mustang Evolution
Old 11-20-2015, 05:29 PM   #1
LeoGMR4558's Avatar
What can be the problem if my stang shuts down by its self. Can it be bad spark plugs? I bought a new battery at the beginning of the year.
LeoGMR4558 is offline   Reply With Quote
Old 11-20-2015, 05:44 PM   #2
I hate it when they do that!
We are going to need more information.
When does this typically occur?
Does the engine seem to run alright otherwise?
Check Engine Light on?
Old 11-20-2015, 05:46 PM   #3
LeoGMR4558's Avatar
Check engine light went on it occurs when I'm at a stop or idling and rarely when I'm slowing down. Cars runs alright other than that
Old 11-20-2015, 05:52 PM   #4
Go to an auto parts store and have them scan for any trouble codes. Also, have them test the charging system.
Post any codes that they find and we will try to help you diagnose your stalling problem.
Old 11-20-2015, 05:56 PM   #5
LeoGMR4558's Avatar
Thanks I'll post tomorrow in same thread
Old 11-20-2015, 06:36 PM   #6
escottcarp's Avatar
I had the same problem on a Grand Prix. At times When I accelerated, the car would shut down.
Eventually I ran it down to a loose wire in a bundle of wires that would 'swing' backwards when I accelerated.
It was really hard to figure out which wire was shorting out. I never had trouble codes, also.
escottcarp is offline   Reply With Quote
Old 11-21-2015, 11:48 AM   #7
LeoGMR4558's Avatar
Turns out it's P0455 Leak or Blockage Detected in Evaporative Emission Control System.
Old 11-21-2015, 12:53 PM   #8
Depending on whether it is a leak or blockage, that P0455 evap code may be the cause of your stalling problem.
The most common causes of that code are:
1. Loose or defective (leaking) gas cap.
2. A leak elsewhere in the system. Such as, the fuel tank grommet, rusted filler neck, loose or defective purge hoses, etc.
3. A defective (sticking) Purge Valve.
I think that you should focus on finding, and repairing, the cause of that code first. It might be causing a vacuum leak of un-metered air. If the stalling problem persists after that is fixed, we can diagnose it further.
Car shuts down for 2 to 3 seconds.then runs again alant007 AmericanMuscle 9 03-11-2013 09:14 AM
car shuts down when dashes appear on odometer dj.deeter 1996-2004 Mustang GT 0 07-26-2011 05:19 AM
Big Problem Guys- Engine shuts down! DMAC Pre-2005 V6 Mustang 7 12-03-2007 10:29 AM
Lexus' Self-Parking car........Not so self parking! Thomas91169 Pictures and Videos 31 12-04-2006 12:17 AM
04:55 PM
