Pinched vacuum hose between purge valve and intake - Mustang Evolution
Old 11-20-2015, 09:57 PM   #1
So I've been trying to figure out some issues with my car, check engine light came on and the code was P0443 - EVAP Control System Canister Purge Valve Circuit Malfunction. So I was looking for vacuum leaks and I found this. So I have 2 questions:
1) is there a name for this or should I just go to advance and buy a hose that size?
2) would that hose be the issue, or would an issue with the purge valve be what's causing the hose to pinch up like that?
Edit: I have found multiple forums on the same issue, but despite many suggestions on those forums, no solution has been found. Other than a few people replacing the lines with copper lines that won't suck closed. But I feel like that's just working around the issue, not actually fixing it. Hopefully someone has figured something out since those forums were posted.
Name:	ImageUploadedByMustang Evolution1448081565.923551.jpg
loganf1221 is offline   Reply With Quote
Old 11-20-2015, 10:02 PM   #2
Hose looks oil soaked, or has been, which will cause it to suck shut
ALLYDRIVER1 is offline   Reply With Quote
purge valve solenoid adwoods1970 1996-2004 Mustang GT 1 08-10-2015 05:38 PM
Purge valve solenoid adwoods1970 Mustang 101 - Tech Basics | Ask an Expert 2 08-09-2015 08:48 PM
Purge valve solenoid GrabberBlue5.0 2011-2014 Mustang GT 3 02-18-2015 10:37 AM
Purge Control Valve Grimace96 1996-2004 Mustang GT 5 05-20-2014 08:22 PM
1996 Mustang P1443 Evaporative Emissions (EVAP) Canister Purge (CP) Valve Brent Pre-2005 V6 Mustang 33 01-30-2011 08:32 PM
01:59 AM
