How hard is the swap - Mustang Evolution
Old 11-22-2015, 10:21 AM   #1
keeney35's Avatar
How hard is it to swap a termi engine and trans into a GT?
Buddy of mine is selling his termi engine and trans for 5k and its low miles he's cutting me a major deal on it..
04 GT: CAI, 3.73, Longtubes, Full exhaust, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 11-22-2015, 12:40 PM   #2
It bolts in. I'm not 100% sure how different the wiring is.
Sent from my XT1045 using Tapatalk
Old 11-22-2015, 12:45 PM   #3
bwright1973's Avatar
It's plug and play and yes you got one hell of a deal!!! Direct drop it start up and roll!
bwright1973 is offline   Reply With Quote
Old 11-22-2015, 02:58 PM   #4
keeney35's Avatar
Cause I could sell by built/forged 2v and swap it in, would it be possible to keep my trans?
Old 11-22-2015, 04:03 PM   #5
parkerz28's Avatar
Decisions decisions lol both are good... Both will cost $$. The 4 valve is better as a starting point but you already have a 2 valve. What are your goals and how deep are your pockets is what determines which way you swing lol
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 11-22-2015, 05:42 PM   #6
Keep the Cobra engine and just put it in.
Old 11-22-2015, 09:42 PM   #7
keeney35's Avatar
Well now I've got a different idea that just came into play, buddy of mine is in a bad financial way..
He has a brand new stage 3r on3 twin turbo kit, everything's still in the box.. And he wants to sell it cheap just to get some quick cash..
Anyone know anything about these kits?
Also with my como 270 cams will they work or will I need to get turbo cams?
Old 11-22-2015, 10:24 PM   #8
The On3 kits are really good provided he bought it recently. They had issues years ago when they were starting up. Also does it come with fuel, MAF adapter/everything else needed? Generally brand new the On3 kit is $5500-$6k when all is said and done before labor.
You will do fine with the 270s although if you are going to do cams and a turbo for sure I'd sell the Comps and get some Cushman 2.5 turbo cams. Not to mention the Comps are going to be on the ragged edge of PTV clearance with the stock heads.
Honestly depends how much he is selling the kit for, what is included in it and if you are DIY or paying a shop for install and what your budget is.
Old 11-22-2015, 10:34 PM   #9
keeney35's Avatar
It will be diy, it's supposed to have everything. I'll double check with him tomorrow.
My pistons are cut tho so idk how bad my ptv would be with them cut but it should be better than stock since there cut, would the valve job I'm giving them at school help any? Or new valves?
How hard is the Eaton swap on a '01? 98StangKid SVT Mustang 3 07-13-2012 10:44 PM
How hard is a motor swap? Topless04GT 1996-2004 Mustang GT 3 08-13-2011 09:45 AM
who has taken the 99-04 HEAD SWAP PLUNGE for a 96-98!?!? ..how easy/hard is it to do bryanbrock 1996-2004 Mustang GT 7 10-14-2010 05:23 PM
How Hard is it to swap a 89 mustang rear end into a 86mustang? bao General Mustang Discussion 3 04-05-2010 06:56 AM
How hard is it to do an engine swap on a 1967 mustang? field Classic Mustangs 4 08-24-2009 01:01 PM
11:24 PM
