Installing BBK O/R X Pipe - Mustang Evolution
Old 11-23-2015, 12:28 AM   #1
So I'm buying a BBK O/R X-Pipe for my 2003 GT and I was wondering what else do I need that doesn't come with it? (Buying from AM) I heard you need a new passenger side manifold gasket for a tight no leak fit? (Yes, my headers are stock btw)
lyonschoice is offline   Reply With Quote
Old 11-23-2015, 07:53 AM   #2
XSlashDashX's Avatar
Yes, get a Fel Pro gasket for the Passenger side. That will be it for the install.
Old 11-23-2015, 08:17 AM   #3
Fel Pro gasket is like $5. You will also need 1/2" drive tools for the passenger side manifold nuts. A 3/8" deep well will not fit and a 3/8" standard socket will not be able to go deep enough to bite onto the nut. Need 1/2" shallow sockets and a 1/2" drive universal joint. Also spray some PB Blaster or Liquid Wrench on all the hardware you are removing and let it soak overnight. Then apply heat to everything before removal. Exhaust hardware that has been in one spot for 12 years is not going to want to cooperate.
Also, consider the UPR vs the BBK. True X design and has the best ground clearance of all the mid pipes.
99-03 Ford Mustang Off Road X Pipe | UPR Products
No free shipping but use the promo code SHAZAM during checkout and save 5%. It works out to be about $185 when all is said and done.
Old 11-24-2015, 05:09 AM   #4
thyreaper's Avatar
I got the bbk and have no regrets but the 4 bolts that are after the cats mine where rusted and wouldnt come out so had to make a hardware store run on downpipes haha... So just be aware cuz mine didnt come with those bolts and mine where in there since 96 so they where stuck none the less.... But besides that enjoy ur new sound and i noticed a small gain up top ( mine still had the 6 cat design stock) and a bbk offroad x pipe with no mufflers and 3in exhaust sounds awsome but i also have tips ( never measured there size or length, they where on it when i bought the car)
thyreaper is offline   Reply With Quote
Old 12-03-2015, 02:44 PM   #5
BeastyStang's Avatar
Does the whole gasket on the passenger side apply to a UPR O/R X? I just purchased one and should be receiving it tomorrow. I emailed UPR to see if it comes with a gasket and to see if i need one.
This is the response i got...
"Hello,
The right side does not require a gasket, and the left side comes with the necessary insert to seal it.
Thank you,"
Should i still get one?
BeastyStang is offline   Reply With Quote
Old 12-03-2015, 06:14 PM   #6
"Hello,
Thank you,"
They sound like they have their sides mixed up. The left one does not need a gasket but the right does...
Either way any local box store should stock them for $6 so if it happens to not come with one just run out and grab one.
Old 12-03-2015, 06:31 PM   #7
I appreciate it. Thank you!
Old 12-03-2015, 11:17 PM   #8
local ford dealership has them for 8 bucks, thats where i got mine couldnt be happier with the fit as well no leaks here
Old 12-04-2015, 07:47 AM   #9
Was the install hard? The entire mid pipe installation?
Old 12-05-2015, 12:49 AM   #10
No not at all, just time consuming to make sure its snug and no exhaust leak. About 2 hours install in just a slow pace making sure not making any mistakes and making sure everything fits perfect and snug. Also would recommend ramps instead of jack stands.
Old 12-05-2015, 10:35 AM   #11
ALWAYS use ramps unless you need the suspension unloaded or are using a lift. Just for safety and not having the stand in your way.
Biggest issue with a mid pipe change is getting the stock pipe off if its original. Recommend putting the car on ramps the day prior, soaking all nuts/bolts in liquid wrench in the evening, again before you go to bed and then again before starting on it and put some heat onto the passenger side problematic nut before even trying.
Old 12-05-2015, 02:54 PM   #12
Damn! I have to invest in some ramps. Thanks!
Old 12-18-2015, 02:08 PM   #13
This might seem like a dumb question. But i got my UPR O/R installed last week, i have probably driven it about 200 miles if that, but i have not gotten a check engine light. I have read in many threads that, that a cel is common. Is this normal? Or is it still in the break-in process. I'm just curious to know.
Old 12-18-2015, 02:26 PM   #14
parkerz28's Avatar
If your not tuned it will pop... My cell lit up after around 50 miles, but every car is different
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 12-18-2015, 02:29 PM   #15
parkerz28's Avatar
By pop I mean it will trigger the check engine light. The rear o2s only check to make sure the cats are working. And since there not there it triggers the light. I didn't want you to think the engine would pop so I reposted lol
Old 12-18-2015, 02:49 PM   #16
Haha. Well if it doesn't turn on say, another 120 miles...should i be concerned?
Old 12-18-2015, 03:16 PM   #17
infamous281's Avatar
It'll come on
Sent from my SM-N910T using Mustang Evolution mobile app
Help!!! Bbk x pipe or h pipe for mustang v6???? Javisolis35 2011-2014 V6 Mustang 7 02-25-2015 09:39 AM
H pipe vs x pipe vs straight pipe 509pony 2005-2010 Mustang GT 100 02-15-2015 08:35 AM
06 gt catted shorty bbk x pipe on a 2012 gt with bbk longtube headers hdez41 2011-2014 Mustang GT 0 10-08-2014 11:47 PM
BBK Long tube headers and BBK Catted X-Pipe Rexex 2011-2014 V6 Mustang 8 10-07-2014 05:36 AM
Just ordered some BBK Longtubes and BBK O/R H-pipe wc3john 1979-1995 Mustang GT 62 07-13-2011 03:17 PM
05:45 AM
