Auto transmission problems - Mustang Evolution
Old 11-27-2015, 03:25 PM   #1
Mfore33's Avatar
2000 mustang gt with 224000 on her. Transmission started slipping or lagging while going into over drive. Also the over drive light is flashing. Fluid and filter gets changed every 50,000 miles. Last change there was no debris in the pan or on the magnet. Plus after I got home you could smell the heat from the trans. Any suggestions as to what it might be and options for repair/replacement would be greatly appreciated. Thanks guys.
Old 11-27-2015, 05:16 PM   #2
bwright1973's Avatar
I'd rebuild it you have damn sure gotten your money's worth with those miles!! Rebuild with good clutches and some other good stuff (not counting converter) I got a guy here that does them for about a grand.
bwright1973 is offline   Reply With Quote
Old 11-27-2015, 05:22 PM   #3
Slater2111's Avatar
It could be a problem with the TCC solenoid. If it's going bad it can do that. But you can try an oil additive that I use with excellent results. It's called DR tranny torque converter shudder eliminator. I don't have the same symptoms as you just shudder at 35-40. I added 2 tubes of it and it's been gone for 1200 miles since my last trans oil change. You may as well try it and see if it goes away before spending a lot of money.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 12-01-2015, 06:23 PM   #4
Mfore33's Avatar
Well first place I took my car to said the over drive band is bad and they don't rebuild. They suggested a jasper transmission for 2500 with a 3yr 100000 mile warranty. Seems steep but I never had much luck using junkyard parts so getting a rebuild seems a better idea. Any thoughts?
Old 12-01-2015, 06:34 PM   #5
Try a different shop a rebuild (stock) with a converter 1500 here
Old 12-01-2015, 06:40 PM   #6
Mfore33's Avatar
Yeah I looked online for reviews on jasper engines and transmissions and found lots of bad reviews. Bad parts and worse warranty/customer service.
Old 12-01-2015, 07:44 PM   #7
Check the price for a rebuilt transmission from Ford. They have become more competitively priced in recent years and generally have a good warranty that is honored at any dealership.
Old 12-01-2015, 08:35 PM   #8
BeastyStang's Avatar
I paid $1500 as well for mine. I recently got it rebuild with a converter and a shift kit installed.
BeastyStang is offline   Reply With Quote
Old 12-01-2015, 08:52 PM   #9
JudenInduven's Avatar
I know, right? 224,000 miles! Crazy stuff.
And he wouldn't need clutches luckily, so one less thing to buy
The chargers are slugs lol
2001 3.8L - Cheap SR CAI, SF4/X4 w/ 91 Octane Bama Tuning, Pacesetter H-pipe and Borla Stingers, Auburn HP Limited-Slip Diff, FRPP 4.10 gears
Coming EVENTUALLY: BBK headers, Eibach Springs, FRPP Aluminum Driveshaft, Maximum Motorsports Caster Camber Plates
JudenInduven is offline   Reply With Quote
Old 12-06-2015, 12:22 PM   #10
fomoco4life's Avatar
Auto trans have clutches too, lol
Old 12-06-2015, 12:35 PM   #11
natestang07's Avatar
Harper engine in my old mustang is still running strong after 35k
Old 12-13-2015, 07:06 PM   #12
Mfore33's Avatar
Anybody use autozone for rebuilt transmissions?
Old 12-13-2015, 07:24 PM   #13
Sounds like a bad idea.
Old 12-13-2015, 07:33 PM   #14
Mfore33's Avatar
Well any good places to get a rebuild
Old 12-13-2015, 10:08 PM   #15
Whoops. They wear out much slower, I'd assume though, right?
Old 12-14-2015, 11:10 AM   #16
Mfore33's Avatar
From what I can tell the only problem is the over drive. Either the power band is worn out or the solenoid is bad that engages it or both.
Old 12-14-2015, 12:09 PM   #17
https://www.fordparts.com/Products/P...ssemblies.aspx
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 12-14-2015, 12:31 PM   #18
Get yours rebuilt or pull one with lower miles and a warranty out of a 2004. Rebuilt will make it 04+ spec which is a 4R75w and much stronger.
If you get one shipped from somewhere, get one from Silverfox. Just google them.
Old 12-14-2015, 04:43 PM   #19
Mfore33's Avatar
Any suggestions on options if I go the silver fox route. Thanks for the info
94 Auto Transmission winterwolf Pre-2005 V6 Mustang 4 01-23-2010 12:40 PM
Auto transmission problems. 6opka Pre-2005 V6 Mustang 4 04-18-2009 02:38 PM
transmission swap (auto to manual) what parts? 6opka Pre-2005 V6 Mustang 8 04-02-2009 03:26 AM
95 3.8 V-6 Engine & Auto Transmission teddy44 Mustang Parts for Sale and Wanted 1 12-06-2004 11:36 PM
Auto vs Auto ERICK Pre-2005 V6 Mustang 4 05-12-2003 11:03 PM
06:12 AM
